Flybridge Windscreen Repair
I4NI
My acrylic flybridge windscreen has pulled apart slightly from it's frame. It has a black caulk material at this joint. I want to re-assemble this joint but I am not sure which caulk to use on this type of acrylic. Any suggestions appreciated. Thanks, I4NI
Sika Flex - I believe the right one is 295-UV. There is a primer that goes with it for surface prep Sika-Primer 209. Get all of the old caulk of unknown identity out first. I believe Boatfix has both.
