Originally posted by vic33004
to answer the original post. if the following seas are tall enough or spaced closely enough that you feel endangered by them you have two choices;
if the boat has enough speed and open water in front, run on the back side of the wave and dont try to crest it.
if the above is'nt possible, point the bow into the seas and run slowly adding throttle as needed for steerage as you crest the wave.
these two options apply only if the seas are large enough to put the boat in danger. as a footnote, taking large breaking seas on anything but straight on the bow, is to be avoided in most power boats.
anything smaller that is not a threat to the safety of the boat and crew is a comfort issue and best determined by the captain based on the boat, seas and wind.
