Foward bilge pump
Larry Paterson
This is my forward bilge pump and when you lift the float switch it works fine until you lift it all the way up then it shuts off. Is this the way it is suppose to work? Thanks...
No it should stay on when all the way up. This could be a major problem in the making. Also 500gph is really small my shower sump is larger. I would consider replaceing it with a 1500GPH pump and seperate float switch. Make sure the fuse and wire size would handle the new larger pump.
Thanks Bill, I have a separate shower sump pump located in the same bilge in a sump pump box. That leads to another question. This pump stopped coming on when the float switch goes up unless you bump it. Contacts need cleaning? How do you get into the switch. Top will not come off.
those sahara arent' that good, I had one that lasted a few month in my tender. get rid of it and get a rule with sep. swithc.
as to your bilge pump, the switch should keep the pump going even fully up! makes no sense otherwide, think about it. if you get a real leak the switch kills the pump?
yo cant' fix those switches, just get a new one. If you really want to be cheap (and maybe have to explain it all to your insurer) put a stop on the switch to stop it from going to high... ok in a bind, otherwise just replace the switch!
