Friday the 13th......
KnottyBuoyz
Well I knew it was going too good. Friday the 13th. jumped right up and bit us on the arse!
We're cruising down the river at dusk doing 3000 RPM rb2@gr5t 24 kts and "BANG" we hit something, the drive kicks up a bit and the vibrations started right away. Slowed and circled back and saw some debris in the water, remains of a tree branch. Nursed her home and docked. Trimmed the drive all the way up and before I had a chance to stick my hand in the water I could see a good portion of the prop blades are missing. It's a VP duoprop and the fwd prop has about 30% of two blades missing and the aft prop has about 20% of two blades missing! Damn, I knew it was going too well!
So my Friday the 13th is mild compared to yours. Went out on a friends boat for some halibut fishing Was supposed to be a test run also so I adjusted carb and shift. Anyway, dropped down(trolling) and got hit right away by something big. Accidently hit the freespool and got a partial backlash. Fish was on but got slack. Reeled up and found SS leader broken. A bit later we were boarded by CG for safety check. No fire extinguisher or horn so the CG accompanied us back to the launch ramp. Short fishing trip...but not expensive.
Not superstitious, but I don't tempt the fates either. Stayed at the dock and waxed the boat.
Ouch! But not as bad as I originally thought. They're fixable.
They're Volvo Penta B5's. I don't know how to decode VP series props for pitch. All I know is they're a matched set. These ones are only a yr old. Probably 20 hrs on them total. The pitch of the aft prop (small one) is significantly different than the fwd prop. I don't know how that works but it does.
My problem was not boating related but it killed this weekends planned outing on the boat. Our main fridge/freezer stopped working so I had to go out yesterday to order a new one and will be stuck in the house waiting for the delivery of the new one today instead of anchoring out on the Wye River and getting in some fishing.
Those must be aluminum props. Are you considering replacing them with Stainless Steel?
Boating in water that does THAT to Aluminum props would make it a very serious mistake to switch to stainless. At least the blades were chopped up on the aluminum.....Imagine what would have happened if they were stainless??...Wouldn't be much left of the outdrive judging from the looks of those.
I haven't been able to find them in stainless, not that I'm looking that hard. Had they been SS I probably would have bent the prop shafts etc. At least that's what the prop guy said this morning. He thinks the fwd prop (big one) is toast. Too much meat gone from the one blade. I'll try another prop guy and see if he can rehab these as a backup set. Just ordered a new set so it'll be a week before we're good to go again. *sigh* Those props maybe had 30 hrs on them. Oh well, that's boating!
Rick,
Sorry to hear/see that! Get 'em fixed up and get back out there...
Bcat
I keep a spare prop on board just in case. That way I don't have much down time when [not if] I strike something!
I had a pretty fun weekend as well. First I ripped one of my brand new screens on the aft curtain removing my dink from the platform, Then i broke the air pump handle off while adding air to the dink. Next, Saturday morning my ac wasn't discharging water. The strainer was clogged. Cleared that and later that afternoon it clogged again. Finally got it running again. Now I need to pull the boat and install what is called a South shore strainer. Basically a strainer with finer holes in it. Then lastly, got home and my fish tank filter pump stopped working. Oh, did I mention the weather sucked this weekend as well. Still a bad day or days of boating is better than a good day at work.
New set ordered. We'll be back in business by Friday. Old ones are being reconditioned as spares! Yet another expensive lesson!
::Shrug::
Went down a size to B4's. They made a big difference in performance out of the hole. Top end down about 4kts. At cruise we loose 2kts upstream and 3 downstream. It'll get up on plane w/o the trim tabs which was virtually impossible before although with a little bit of tab it jumps right up and goes. No bogging down like before. The drive seams happier. We used to get, what I thought was, rumbling from the u-joints which might have been caused by the excessive pitch. There's no rumbling now.
I guess inadvertantly I've stumbled on the correct props. We started with B6's when we got the boat and it was a dog. Wend down to B5's and it got better. Expensive way to fine tune your prop setup though! *lol*
My horror started June 12th as we are setting anchor in a cove in Cayo Costa, we realised that the cove was under attack by big nasty green flies! The ones that bite! That really sucked so we closed down the eisenglass and made due for the night.
Friday the 13th, we got up and left early, figured I would tow the dingy to Tween Waters ( a twenty minute ride away) rather than stow the dingy back on the bow, remove the engine etc. Bad idea! While under way, and out from the fly zone we decided to stop off the channel and open up the eisenglass, not realizing that the dingy being towed behind us, has now drifted in front of the boat, (not having my tow rope with me (floating type) I used some dock lines to tow) I accidentally hit the gear shift lever forward which made the boat move and then stop abruptly as the dock lines wrapped themselves around my shafts and props.
Guess who had to get the dive gear on at 8:30 in the morning? Oh well, it was after all Friday the 13th, luckily for me the water was clear and warm.
On our return home Monday we hit down pouring rain and thunder all the way home for 5 hours strait! At least I did not have to wash the boat when we got back! This is why we all love boating!
