Fuel Flow Question
pgilbert
See photo below (tilt to see accurately - did not show rotated as it does in photobucket). This shows the fuel flow monitor (black) in between a small filter (clear) and the actual fuel filter (white). My fuel flow indicator, which is part of my Navman GPS set up, is not reading accurately on one of the motors (twin Volvo 5.7 OSI-D) on my 2005 Chaparral 310. I believe the clear filter needs to be replaced. Do you agree?? I went to a dealer that does Volvos and they sait it is not a Volvo part. Any ideas whaere to get it and is there a specific name for that part??
When you say "tilt". do you mean that the fuel transducer is NOT vertical? (Your pic has it vertical!) It needs to be!
Is that clear filter glass or plastic? Glass is a safety hazzard! I use an all metal NAPA in line filter.
I once had a problem with one of my fuel transducers. Removed it, blew thru it (in the correct direction), replaced, and all has been well for 3 years now.
Sorry for the "Tilt" comment. When I previewed the post it showed the photo rotated 90 degrees. What you see above is the proper view and it is a plastic filter.
that filter doesent looked plugged to me. you can buy them at any auto store. meeting code is another question.
What Steve says.....all metal filter. No glass, no plastic - heat issues in the engine compartment could break it and have fuel spraying everywhere.
Internal paddle wheel of fuel transducer could have foreign debris lodged. Blowing thru, in the reverse direction, may back out the debris easier than blowing it thru.
My Navman does the same thing, reads the right amount one time fluctuating amounts the next - both sides. I have spayed with carb cleaner, and it works, for a while then same thing again.
I was warned about that, so I chose NOT to have a fuel flow meter for my diesel refit in 2005.
I do miss the Flowscan fuel flow meter I had with my 454's which was accurate to about 3 gallons on every fillup.
inline glass filters are not "legal" in gas boats. this one is plastic but i doubt it's safe... USCG approved hoses are supposed to resist a fire for a certain amount of time... enough time to put the fire out. I'm pretty sure this thing will melt in second, get it out of there. now.
i don't think the filter is affecting your flow meter reading... your engine should have a canister type fuel filter, that shoudl be fine, no need for anything else. if you really need/want to add a primary filter/separator then get a racor...
If it is on an inboard it is not to ABYC standards. Agree that any auto parts store and Wally world will have the metal filters. However it may be the transducer. I had one which was not working properly and Navman replaced it. With the sale of Navman, I don't know if it will still stand behind the product.
