Michael Koch
- Apr 16, 2005
- 17011
- 11
With the price of fuel, I have been looking at Hydrogen generators. From what I can find out they work best on carb. engines. They will work on fuel inj. but you need additional equipment. 02 sensor.
They need to produce at least 3 L. per min. of HHO. Some of the units will produce that and more. 3.7L per min. Milage increase is 30% to 60%. So if your engines are using 1 gal per mile, then an increase of .5 is possible. On a 200 gal boat that is and increase of 100 miles. The units that only need water added and no cleaning are what a person would look at. Also amp usage. Nothing more than 20 amps 15 would be better. Some units as they heat up use more amps. Also you would have to look at the amount of heat the unit puts out. If it is a plastic unit it can become hot enough to melt the plastic. I know Hydrogen is very explosive, but remember it will not go into the bulge, (lighter than air) Also if you run your engines at lower RPM this will keep the engine cleaner also they will run cooler. It works on Diesel as well as gas. The cost would be around a $1000 for both engines.
I put this out there to see what everyone thinks?
I have a friend who has built a Hydrogen Gen. Was at a farm show and there was a booth set up selling them. He went on the internet and found info on building his own an gave it a try. It did produce HHO, but not enough. .75 L per min. He had cut a few corners in the construction. This unit also produced a lot of heat, and as the heat went up so did the amp draw. If you google Hydrogen Generator or go to you tube, there seems to be a lot of people out there working on this. I have no idea if a HHO gen. is at the point where it has become something that can help. I have seen some HHO gen. use a pulse system to produce more HHO gas than a steady current system does. The pulse uses less amps and runs cooler I believe.
I have more questions than answers.
