Originally posted by Radioactive
Well, since you don't provide the needed info, I'll just give you the forumula for a Wild A#^ Guess:
Take total HP and divide by 10. That is your Gallons per Hour, at Wide Open Throttle.
Take half of that number. That is your GPH at "cruise".
Now, combine the Gallons per hour, with the speed ( Miles per hour ) to get MPG.
Note that this is an ESTIMATE. You should -always- prove these numbers, for your boat, in an assortment of conditions, to get good info.
If you are ready for a long trip, have you been collecting fuel usage data? That is your best source for info on what kind of range you will get.
Originally posted by thataway4
Probably burn 10 to 12 gallons per engine an hour or about 20 gallons an hour at cruising speed. I like to have fuel flow meters, because you can find the most effecient speed--and basically they will pay for themselves in a year or so. (not expensive for Lowrance or Navman meters). Since the boat only holds 172 gallons--figure 150 for safety--you can run about 7 to 8 hours at 20 to 22 mph--and that will give you range of 140 to 160 miles...
Thank you. I was looking for a good guess. I am not going to run it anywhere close to empty.
For the most part express cruisers do not have a long range. If you slow to displacement speed, (lets say 6 knots) you can double the range. On the other hand, if you get really bad weather, you may not get that good...So plan well.
