fuel supply problem...please help
ocdoug
i have a rebuilt omc 460 everything new...Edelbrock carb. intake manifold electric distributor and starter...new carter fuel pump and i just put a fuel pressure gauge in...the problem is, my fuel pressure goes down to 1 psi when over 3800RPM and mosttimes after cruising along at 3300 rpm's after about 10 minutes...what can I do?
Did you change the fuel filter? How old is your gas?
new fuel filter and gas was old so I put a boat load of sabilizer in and put another 50 gal. in about three times now
What does the fuel/water seperator look like? Are you running ethanol? Did you mix ethanol and MBTE?
You could try running it from an isolated portable tank to help narrow your fuel delivery problems to before or after your tank. I would start by running it from the carb and worling back at different points to the tank.
Check your carb bowls for build up. If you are running E-10 there could be build up in the bowls.
Check your fuel pick up and anti-siphon as blow back and blockage could be an issue
EDIT: You note that fuel pressure is dropping by 1 psi, are you seeing a corresponding RPM drop as well? If not, the fule pressure gauge could be faulty.
nice...thanks, fuel/H20 separator is new. I will check fuel pick up from tank first and then I will try running off isolated tank. and yes RPM drops with fuel pressure. thanks again for the info....hope your right...but anyone else out there with an idea, don't be shy.
Overheating and fuel delivery problems are the two most common complaints.
You will get answers to your questions but if you sign up(look at the picture of the anchor at the top of the page) to help defray the cost to run this site, you will get access to the
http://www.boated.com/forum.asp?FORUM_ID=67
It has articles for the beginner as well as the experienced boater. Money well spent.
Low fuel pressure can be caused by a restriction as well as an air leak in the fuel delivery system. In your case, the problem is somewhere before the fuel pressure gauge which narrows it down(assuming the gauge is good) The most likely culprits are clogs in the anti-siphon valve, pick-up tube or vent line. The other possibility is an air leak in the fuel line/hose or a loose or leaking fitting. Except for the pick-up tube, they're all relatively easy fixes.
