I just found out that my aluminum fuel tank is leaking & needs replacement. I had all of the fittings, hoses & sending unit checked & they are all fine. Does anyone have an estimate of what this might cost & where I might go for this work to be done. I want to compare prices to the marina mechanic when they get me a quote. I undestand the engine needs to be pulled & the tank pulled through the wall after a hole is cut between the aft cabin & engine compartment. UGH!!! Seasons over
