this is a great article that helps explain this often complex and troubling issue.
http://www.passagemaker.com/Magazin...Article/tabid/277/articleID/1237/Default.aspx
as the author notes, if you have an electrical issue on your boat it is wise to hire a marine electrician. a galvanic survey will find the source(s) of the problem(s). While the solutions may be very simple and straight forward, finding the source is the challenge.
