Al, the "base maps" I am referring to are the official NOAA nautical charts. In your area, especially if you travel in an area of valuable commercial traffic ( and/or high maritime population ) those charts may, in fact be more accurate. In most areas, esp. those with little or no large vessel traffic and relatively low population, they simply draw accurate channels onto very, very old charts. They then label it "official", and the digital chart companies create the digital versions from -that- data. Sure, each brand of digital has it's own strengths and weaknesses, but if the source data is 150 yrs old, and you are talking about a swamp ( which changes rather fast, actually ), then there are, and will be, many, sometimes large, errors.
Two quick examples, from my area: If you travel the center of the Jourdan river, from the mouth to I-10, about 1/2 of your trip will, according to the chart, be overland. ( the river has changed course over time ). Another is traveling through Cat Is channel: You can, in fact, travel a straight line from Pass Christian harbor, to Freemason Is. But the chart will show you crossing over the swamp. For the past 30 or so years, the swamp has receded, and the entire rout has plenty of water ( which around here, means 6' min at lower of low tide ). And any GPS-based chartplotter will faithfully show your overland travel...
