Gas with Stabil
fizerocks
I know every one has their own opinion when it comes to storing the boat for winter with or without full gas tanks. I've always been one to store with less then a half tank with stabil. In the spring I would fill the tank with fresh gas without any problems.
I wondering now though with gas currently at $2.50 a gallon in my area if I should go ahead and fill the tank versus waiting for spring when who know's what gas will be selling for.
Open for anyone's thoughts on the matter. I will probably need at leat 115 gallons to fill up.
Thanks - James
You are playing the come. What if it's 1.80 in the spring. That's $287.50 v. $207.00. That's and $80.50 difference. Could easily go the other way as well.
I have slightly less than 1/2 in each tank I am going to fill up to half and hold my breath. I have already stabilized the fuel.
If I could get fuel without ethanol, I'd fill up. I don't want 300 gal of gasahol in my tanks to phase seperate over the winter even though I use Startron.
I'm fortunate in that respect. My small marina still has ethanol free fuel. The extra 100+ gallons is purely economics. He is still at $3.99 per gallon leftover from summer. To his credit, when others were adjusting prices to maintain a level profit, he held firm at $3.99.
I am under the impression that you should store the boat with either nearly full tanks (nearly = room for expansion) or empty. That helps prevent condensation buildup from temperature swings.
Per Darin's comments except for the "empty" category, our marina (Wash DC area) always recommends full tanks to minimize condensation between boating seasons.
I used to follow that logic, but I read (somewhere) the amount of condensation would not be enough to fill a seperator. Three years of less than full stabilized storage and no problems. I have to wonder if the full storage issue comes from the gas seller.
I am sitting here wanting so badly to make some wise acre crack about I am planning to fill the tanks and then burn the fuel, or something. But I won't rub it in that down here I do not have to worry about not burning fuel in winter. I will not say anything. I will be nice.
G
I'm with you. Since ethanol, I have been draining my tanks after I am on the hard. I have had no problems storing with empty tanks.
I store with what's left in the tanks and well stabilized. Haven't had any problems YET.
The last time I left my 90 gallon tank half-full it ended up costing $2k to get it fixed. It was, however, during the transition from non-ethanol fuel to ethanol fuel. The combination of the moisture in the tank from being half-full and the wonderful properties of ethanol ended up costing me a lot of money.
Since that time, with 100% ethanol fuel, I have left the tank full and Sta-Bilized with no problems. I will continue to winterize with a full tank.
Peter
Peter
But did you stabilize the fuel before it cost you $2K?
Every winter, I store it full. Never a problem. I add Stabil, and last year I also added the special Stabil barnd of treatment for gas that has ethanol.
During the season, I use 87 octane. I fill it with 93 octane before winter storage to account for octane loss. Not sure if the octane loss thing is true, but I haven't risked it. Everything is good.
Change your fuel filter, too.
