general question
fad2blac
just tore out the rat hair/carpet from the cabin of a 1975 sea ray, the wood appears firm, intact, without rot. Is it reasonable being all the carpet and rat fur is out to a apply marine resin or Gluvit epoxy sealer?
thanks in advance
If you clean it real good so the bumps won't show, I don't know why not. Some cheaper built boats have a thin coat of gel coat or resin on some of the bulkheads under the decks to protect the wood from water rot.
I don't know if this is right; maybe someone who does can tell us.
If there is NO rot, I think I would just sand it thoroughly to get it flat and get all the crap off. Then just mix up some resin and roll a couple coats on it. Then just glue down the new carpet over that. Any thoughts?
You are going to put carpet back on it?
I'd use a coat of Gluvit. Works well and seals everything up, even if you are re-carpeting.
i think i am sold on the sand it down and a coat of gluvit, i plan on replacing the rat fur with vinyl and carpet the rest, appreciate all the input :)
