Generator for small cruiser
Chesadena
I've been watching all the threads for carry on generators on this and many other forums. I've also read about this topic from postings on the web. The conclusion seems to be "don't use a carry on generator, you'll shorten your life span dramatically".
So what to do? I have a 24 foot cruiser with A/C and would like to be on the hook for a night with A/C when it's 100 degrees outside. I can't fit a marine generator on the boat there's just nowhere to put one. So...get a bigger boat? ;) Are there no good options?
Ridiculous! Of course you can use a portable. I've had my Honda 2000 for almost 3 years now and absolutely love it. Any generator, whether built in or carry on, is going to emit CO. You need to make sure you use it in a well-ventilated space and never use it when you're sleeping! Get a couple good CO detectors, put the generator in a spot away from you (swim platform or, in my case, I put it on the bow of the boat - and you're all set.
Incidentally, I wouldn't use a built-in generator at night while sleeping- NEVER.
I'm thinking; putting genny on bow will blow any CO toward bulk of boat as bow will always face into the wind when anchored. Swim platform w/b much better choice in my opinion.
DON'T do as I do; DO as I say !! I sleep with genny (built in) running. Have 3 CO detectors on board & genny is wired to shut down when CO level rises. I check main CO detector with smoke from lit cigarette every spring; it shuts genny down.
"So what to do? I have a 24 foot cruiser with A/C and would like to be on the hook for a night with A/C when it's 100 degrees outside. I can't fit a marine generator on the boat there's just nowhere to put one. So...get a bigger boat? Are there no good options?"
a) Get a bigger boat.
b) sleep nekid, on the deck.
Smaller boats are not really designed for ovenighting unless you intend to "rough it". There is no "good" way to carry an A/C and Genny. Think about it: the pure volume of the genny and A/C ( and spare fuel ) is more than most ice chests. You are giving up a LOT.
Why not just enjoy the "camping out". If it is too hot at dusk, wait an hour, it will cool off. ( Is it REALLY 100deg overnight? )
Perhaps I am just acclimated. When young we slept without A/C at home as well as on the boat ( In New Orleans, LA ). Sure A/C can be mnice, but it is far from being necesary. Imho.
Or, just get a bigger yot.
Either follow Bill's advice, or just head back to the slip at dusk and sleep there with the AC cranked. You can always head right back out first thing in the morning.
Just a thought...
Paul
Put hte genny on the swim platform and run the A/C at max cold until you get ready to rack out. Turn off genny, and turn on DC fans. Sleep like a baby....(waking up every 2 hours with wet drawers...)
Seriously tho Sleep well.
Thanks for the responses. I have a 24 foot regal 2465. The only thing it's not capable of doing while on hook is the A/C and the microwave so even without the A/C it's not really roughing it. I admit I do like my A/C though. I keep it at a boatel so I have no slip to go back to unless I ride the forklift back to the rack and then I have a no water problem:).
Bob, is that auto generator shutdown a commercial product?
Not that I wouldn't like to sleep nekid on the bow but there might be some passing boats that try to rescue me by pushing me back into the water.
As Paul says ... run the Honda with a/c as full cold til you are ready for bed ... us 12V fans and all will be well. Use common sense when using the Honda ... CO detectors .. do not run while sleeping etc.
Years ago I had a 24' boat and used a honda 2000 no issues, I did let it run until cabin was cold then shut done to go to sleep, early in the morning I would start back up.
Chesadena, it was a readily available CO detector at the time (1993). Not at the boat right now but I believe it was an Apelco CO detector. It offered 3 options while wiring:
When CO approaches caution levels (don't recall those numbers)
1) Sound audio sound; PA horn or whatever you hooked up.
2) Turn on bilge blowers to remove CO. I always run blowers anytime genny is running!
3) Shutdown genny
Probably doesn't help much but contact some tech support at various CO detector mfgrs. re these features.
There are many options and many costs. What parameters are you presenting to live within? It really may not be that hard to get what you want, when you want and at a reasonable cost.
I have seen many boaters sailboat and power boaters using Honda Gen,just use it safely,they use them for charging batteries on sailboats all the time.
What is the difference between using a CO detector that is for your home and one that is used on the boat?
Chesadena. . . .Get the Honda. Put it on your swim deck. Buy two CO detectors, and enjoy your air conditioned boat. I did it for years on my Sea Ray. During the day I used to put it on the bow pulpit with a bungee so we could keep the cabin cooled while we were partying in the cockpit. Moved it to the swim deck before bed time. Gotta have at least two CO detectors. Never once did either of my detectors ever show (digital read out) any sign of CO. Day or night.
That's exactly what I do. I have 3 digital CO detectors and have never had one show anythng but "0". I'm an old man so I'm up to the head 2-3 times a night and always have a look at them just to be sure but never had even the hint of a problem.
I use the Kidde Nighthawk Digital CO detectors.
I hung my Honda 2000 off my pulpit bow rail on my 26' cabin.It ran all night long for the AC and batt chargers.I had two CO detectors inside and never had an issue.I've done it for many years.
When you decide to buy a little genny don't waste your time with anything less han the yamaha and Honda 2000.The yamaha puts out bit more but the Honda is tried and true.It runs in the pouring rain and never skips a beat.
What's the plan for when there is no wind or it dies at night while you are sleeping?
Before A/C came into use on small boats there were basic design features that helped to make the cabins more comfortable. The old cabin cruisers (even our 26') has a lot of screened windows and a screened cabin door.
I've anchored out in daytime temperatures of up to 109 and still slept comfortably at night without A/C, but the climate helps us out a lot with overnight cooling and breezes.
If overnight A/C is not a possibilty for a small cruiser, you can choose a model with good passive cabin ventilation (usually windows). Some boats differ from the basic bleach bottle design enough to offer this feature.
Well; 1) If the CO level were to rise I would see it on one of my 3 CO detectors and shut the gen down. 2) If it went high enough and I didn't see it one of the 3 CO detectors would go off in which case I would shut down the genand open all the windows and hatches.
However, neither one of the two above scenarios has even come close to happening. CO detectors have never shown anything but "0" except during the day under way with a breeze on the stern and that was engine exhaust not the gen.
