Generator Quote...OUCH
"Very likely you can tee off the head pickup throughhull for the water supply."
I wouldn't tee off the head or anything else. Not just possible because of starvation but because head, AC, and main often have scoops which are a big no no for gennies.
when i first replied, i though the quote was for the 7kw... how much extra? and you havent' told us how many AC you have and how many BTUs? 5KW may be enough if the price difference is substantial.
and i woudl really quote a low CO version. Others are right, shop around for price even if you have to take the boat somewhere else to get it installed.
I assume you have two 30amp shore power inputs which is typical for a boat your size.
IMO, you should have a generator that has capacity that closely approximates the total AC load for your panel. That way if you try and exceed the genny output, you will pop one of the 30amp main breakers on your panel and not the generator breaker(s). CB's on the AC panel are a lot easier to access than the genny breaker(s).
In other words, total wattage capable for your panel is 30amp x 120V x qty2 = 7.2KW.
Therefore I would go with the larger gen.
Jim D.
I've got a '99 Carver 350 Mariner (same boat as yours - just different layout). It's running a 7.3Kw Kohler - I can run everything with it.
I have one air conditioner (Marine Air). 2 burner stove, oven, water heater etc.
2-30 Amps 115 A/C. I sent an e-mail back attempting more negotiations. If I can get the 7kw for the original quote it's a done deal.
Thanks for all of the responses...I appreciate them all!
5kw is plenty of power with one large a/c unit.boat show prices in northen virginia last weekend were kohler low c.o. 5-ecd without cover 6310.00 with sound cover 6995.00 westerbeke 5kw with carb.5610.00 safe c.o.6966.00 this is plus shipping the rest of the prices seem right in line labor is a bit low but this area has a high cost of living so you cant realy compare but the pricing should be real close good luck
my last boat a Commodore 402 from regal had a 5KW gas genset and it was plenty. there was one A/C unit along with a cooktop and water heater. the rest of the loads were relativly small. the misc 1400 is a good deal if it includes hauling the boat for the thru hulls. One item to consider when the boat is out is an air water separator. this will need an additional thru hull at or below the water line for the water discharge. believe me you will be glad you added this as it gets rid of almost all the exhaust noise outside the boat. if the unit has a sound shield available for the genset itself, i highly reccomend it. before i added these items, i could'nt wait to shut the darn thing off while at anchor. now i hardly know its running its that much of a difference. the current unit i have is a Kohler 8EOZ diesel.
"if the unit has a sound shield available for the genset itself, i highly reccomend it. before i added these items, i could'nt wait to shut the darn thing off while at anchor."
RPM is critical to noise when it comes to gas gensets... what did you have before? 3600rpm Kohler?
the 1800 Westerbekes are very quiet... blowers are usually louder.
I have a Westerbeke 7.0 and it runs everything on my boat with no problem. It is very quiet. I have it located in the lazerette. The starter is louder than the unit itself. I run it as soon as I disconnect shore power until I reconnect shore power. Nothing like a cool cabin after tying up on a HOT day.
Well, I stumbled onto a Kohler 7.3 carbureted, but with a sound shield for $5,200. My labor quote went up to $2,500, due to not purchasing it through them. So, I add another $1,700 or so for installation kit and misc. and I’m done!
Now of course I'm hearing comments like: get a fuel injected genset and get a Westerbeke instead. I'm happy with what I'm getting...I think ;)
