Genny
BillyBo
Quick question... Can a genny be running while underway at cruise speed... Don't think I would really ever want to, but you never know...
Mine runs from the moment right before I unplug the shore power to the just after I plug it back in regardless of speed
sure... why not? you didnt' say what kind of boat you have but the only thing to watch for is that on a small / fast boat you could get some air under the boat, especially in a chop, which could reduce water flow to the genny.
I run my Tiara 32 open at cruise with the genny running in order to have A/C and a cool cabin when getting to my destination. It depends on the weather. Most of our friends do this as well. I think it may depend of the type of cooling water pick up you have so this advice should be considered brand specific.
Its a 31ft Cruiser, just thought maybe if I wanted a hot roast beef sandwich while underway the wife could nip down and make it if I had genny running... She is going to be glad to hear its possible...thanks guys
Not only possible, but that's what it's designed for.
We run ours when we unhook from shore power until we return. Although when we are on the anchor/hook and it's cool enough we shut it down at night. Thats just to be good neighbors.
My cruise speed (crawling speed) is ususlly 7-8 knots but I have had it on running at 30 knots with no problems.
Ablolutely. Make sure the pickup is the correct type. If it is factory, I am quite confident it is, however, some aftermarket folks think a scoop type intake is what is called for. Those folks are wrong and you will trash the gennie via water injestion.
David, re the scoop intakes, wouldn't you risk water ingestion even if the genset wasn't running?
Me [:-dunce]. You [:-graduate]. Me [:-banghead]
You are indeed correct. You will experience water injestion either way.
STARTING a water injested engine will trash it
the genset can typically run for many many more hours between major overhauls compaired to the mains because the load is steady and the RPMs on an 1800Rpm unit are low. normally the genset wears out from rust rather than hours on a pleasure boat. running the unit under load often is the key to longevity. the heat exponges the moisture from the powerhead and keeps the brushes worn, if your unit has them. most gensets need to be exerciesed weekly as part of a long term PM program.
