Getting Old?
fountain27
Had one of the best day's on the water yesterday. Launched the new dink and was even able to get the dog onboard without incident.
My plan was to store the dink on the front deck so I do not have to inflate / deflate after every weekend (PIA). Much to my surprise I could not lift the dingy over the bow railings! I could lift the boat to the railing but not over.
The dink only weights 100lbs but it felt like 300. [:-ashamed] Needless to say my lower back and shoulders are killing me today.
Any suggestions on hoisting the dink over the bow railings? Maybe call Balco? :D
I appreciate any suggestions. Hope everyone had a great weekend on the water!
Originally posted by Pigmeister
Nice looking lake and dog. Where is that?
About 10nm away from the Chesapeake Bay on the Rappahannock River close to Deltaville, VA.
Tie a doggie bone to the bowline, then toss the bone aboard. Let the doggie pull it aboard! ;)
Here is an inexpensive portable davit that might do the trick. A friend of mine mounted one on the aft portion of his flybridge and lifts his small dingy up there easily. It also stores quite compactly.
Garhauer Davit
how were you lifting it ? i think the key is to lift from a point near the CG
so that once you have that point up to the rail you can just tilt the boat down.
or since the stern is heavier, lift from the transom, attachign a line either on the handles
near the stern or to the rear of these lines on the side. lift up to the rail, then push
down on the transom to lift the bow up...
Wow. A Dobbie in a dink. I will never forget what it was like to pull into the triboro bridge toll booth in a Triumph TR6 with the top down trying to hold my buddies full grown big bone dobbie back from the toll collector. She had some really big eyes!
But carrying the dink up without a davit even if it only weighs a 100 pounds is going to get you into back trouble that lasts. I gave up when we had our 25 foot sea ray and got some weaver snap davits so I could fold it up on to the transom. With a 4HP unloading the engine should not be a real pita.
Subsequently to having the weavers on, I heard (from a surveyor that looked at my boat) they have been the subject of some lawsuits because people get hung up on their ribs when they slip on the transom and land on them. If you go this route get the removable kind.
a few weeks ago, I carried Naomi's 125 lbs american bulldog down the 6' ladder from
the aft deck to the swim platform and into the the dink. then back up later on. never again !
will use a doggie PFD next time aroudn and hook him up to the crane to get him down :-)
We store ours up on the bow, i can get it there myself, but a second set of hands, even the admirals helps.
My method is to lift the bow/nose up with the line I keep on the tow line. Flip it over so the top is up against
the boat and the bottom facing up. Lift up and put pressure on the front, like a lever over the bow rail, tricky part is watching the oars dont get stuck on the rail. Like I said, 1 person can do it, 2 even a not so strong second can help,
at least to help the lever motion while your lifting.
Remove the dog before you try to lift the dink up over the bow rails!!!! LOL
Fountain, your definitly doing it wrong. Your wife should be in charge of deck things. Greatest anchor wench there is.
