Good Windlass Not Working
GNYLS
Hello Everyone,
I recently bought a 1989 30' Searay Weekender and I am having trouble with the windlass. It is a "GOOD" brand windlass 1/2 600. I have a breaker switch on the dash that controls a toggle switch that controls either Nav lights or the anchor. The light for the anchor comes on but when I use windlass control to lower the anchor nothing happens. It did just work a couple weeks ago. I am going down today to take closer look. The light being on next to the toggle does mean the breaker is good correct? Anyone have any thoughts?
George
OK... is it a rope-rode only windlass? Also, is it a "Free Drop" windless? Good makes both kinds. We had a "Rope-Rode Only, Free Drop" Good windlass on the Carver. When you hit the "Down" switch all it does is "unlock" the grip on the rode. We often needed to give the anchor a little kick to get it started. Once you get the proper depth and scope you need to hit the "Up" switch to retract a couple of feet of rode and "re-lock" the windless. We found that once we learned the proper operation of our Good windless it worked perfectly. If the above doesn't solve your problem it could be an electrical issue. In that case I'd start by checking and cleaning all elecrtical connections at the switch and the windless. If it still doesn't work you can call Good Windlass Customer Support. They can be great help.
Good luck George and let us know how you make out.
The toggle switch that controls "the nav lights or the anchor" probably just selects the nav lights or the anchor light. I have a similar setup.
Even if the windlass control gets its power from the nav light switch (unlikely but possible) the windlass reversing panel or relay will have another power source, AND another breaker. Somewhere between the relay and the battery you should find a high-amp breaker.
How can it be a "good" windlass if it is not working? Sounds bad to me.
G
Kinda like the "Ideal" windlass I just replaced. It worked perfectly but was far from ideal for my boat.
Ah, the point about the Nav vs Anchor Light switch is a good one!
Well I was out today and tried giving it a little kick to unlock it but no go. After looking at the toggle I agree it is just for the lights. I am going to give Good Windlass customer support a call tomorrow. I asked my marina for help and they just said they do not work on any type of windlass. I think they just want to work on the engines only. What ever happened to full service?? Anyway thanks for everyones help if I can't get anywhere with Good Windlass I have an appointment with another marine service next week.
George
You're not giving us much to go on. Does it run or make any noise at all? do you get any clicking noises?
This may be a stupid question but did you check the breaker? Also, all my boats also had a seperate switch at the helm that actually turned on power to the windless, seperate from the Up/Down switch. Does yours and have you checked that?
Sorry guys, no it does not make any noise at all. And yes it does have a seperate switch which I beleive is the breaker.
I was told that this model had the breakers in the dash. I am going to check that next. Thanks....
On my '93 Silverton 37C there is a 50 amp push button breaker in the engine compartment 2-3 feet from the batteries.
Wow that could be it. I am going down after work to check this out. Obviously I am new at this So thanks for all your help.
Yes I also have 50 amp push button breaker. Stupid question but how do you know if the breaker is on or off? The button does not seem to click into eaither position kind of sticky. Is there a way of telling if it is bad?
look mand see if there is a lever on the breaker, you push it up to reset it....
Open the housing that has the 50 amp push button breaker, measure voltage from a known ground, you should have voltage on both sides of the breaker. If you do then try measuring the voltage when you have someone trying to operate the windlass. I the voltage isn't there or it drops drastically you need a new breaker. Also check your wiring to the windlass it could be have corrosion or be loose.
near the windless you should see the wire leading from motor to solenoids. there is also a fuse there you will need a circuit tester o see when you push lower or raise if you get voltage on the wire to solenoid top little screws and if soeinoids work voltage acroos terminals if no voltage to either terminal then problem with battery circuit breaker or wire to solinoid. if all voltage check out okay then motor is bad
Remove the switch from the dash and check for a broken or corroded wire. Then get up in the anchor locker and check for broken or corroded wires. the dash switch controls solenoids at the winch to power up or down. The heavy wire goes dorect to a breaker and then to the battery. The solenoid wires are lighter and if they have no power they will not close the solenoids at the winch.
Thanks for everyones help. It ended up being a bad breaker in the dash.
