GPS Antennae?
Tanqueray
It seems to me that I remember seeing last week or so (memory is going) a thread on here (maybe somewhere else) about a GPS type antennae that simply plugs into the USB Port of a Laptop and turns your Laptop into a GPS Reciever? Seems to me that you could also download Maps for different areas from Maptech? I'm probably full of crap but has anyone else seen anything like this and if so....How do they work?
http://www.boatered.com/forum/post.asp?method=ReplyQuote&REPLY_ID=527373&TOPIC_ID=106682&FORUM_ID=1
Gary, I use my 15" screen lap top pc as a GPS all the time when traveling in unknown territory (ON LAND). Small yellow antenna sits on dash & hooks up to pc with usb cable. No internet connection needed. I have two programs that work with same antenna; Microsoft's Streets & Trips and DeLorme Earthmate Street Atlas. Never tried to see how much if any water surface would show. I'm positive it would show your location since that's coming from a satellite but won't show buoys.
If your computer is set up w/ Bluetooth technlogy, there are even Bluetooth wireless WAAS-enabled GPS antenna/receivers available for around $75.
You can download charts from "freeboatingcharts.com" and yes they're free. You'll need an internet connection to download them but not to use them. You can also download "Sea Clear II" also free. Sea Clear isn't the best (or the only) nav program out there but it IS free and it DOES work. With one of the GPS antennas listed above and your laptop you now have your handy-dandy chartplotter.
Sea Clear also allows you to MAKE YOUR OWN charts... so you can download a satellite pic from Google Earth and make it into a chart. It's tedious but it does work; I've done it. Unfortunately Google Earth doesn't tell you how deep the water is... You find that out the hard way! :D
Holux makes a USB or Bluetooth GPS "mouse" that plugs into your laptop. The antenna side has a magnet so you can stick it to metal. I found that the popular chart program "Seaclear" found the Holux just fine. I had a flashing yellow dot on my chart program showing my location.
The "boating Maine" web site has an excellent tutorial on use the free chart program "seaclear"
stmbtwle, Willie, I don't really need another GPS on board but it would be nice to have a back up if needed. Are you saying that I could use the antenna I show in my post above; download chart(s)from "freeboatingcharts.com" or "Sea Clear II" and it would work like my Garmin GPS currently on board ?
This is great information...Now all I gotta do is spend an afternoon looking at all the sites. Thanks-a-lot
