GPS chart plotter PascalG
Scottath
PasscalG, I'm at the point with the explorer plus where the adjustments are to my liking. I had mentioned it was confusing. There is a feature that projects your path which made the ships position be anywhere on the screen which was what made the unit a little confusing to me. I found a option on how to turn that off. Now the ships position is always in the center of the screen. That projection feature would probably be neat for people in route.
good... on the garmin you're always in the center unless you move the pointer...
these things can be customize to suit your preferences... for instance some prefer to navigate heading up.. I hate it ! and prefer my plotter to always be north up... less confusing in my opinion
I prefer north up also. It makes correlating with my paper charts much easier.
Agreed, however it is a learned process and refresh rates on some units make north up refresh very tedious.
I just turn the paper charts [:-bigeyes]
I prefer North up - old holdover from aviation days. The Admiral prefers Heads Up - she is the sensible one. Two or three quick button pushes and you can switch back and forth with ease on our Raymarine.
I'm north up too. LOL I'm all set up like its a standard horizon.....
North up on the plotter, but NOT on the radar.
I need actual relational layout on the radar.
As usual, I'm a bit off of center ( :).
I keep the plotter "chart up" which is usually equal to North up( vessel always centered ), and the RADAR on "Heading Up". Whatever makes it most clear to the user...
