GPS chartplotter off
cmariner32
I've got a Navman 5500i GPS chartplotter. Last week we took an evening cruise up to one of my favorite waterfront restuarants and noted that it was not tracking properly. I have the C-map chip for west Florida and have never seen it this far off. I had sent it back to Northstar last year for a software upgrade and to fix an internal antennae problem. When tracking, it is showing my position outside of the narrow channels-as much as 20 yds. I even had a route tracked from a previous trip and those routes are now superimposed outside the channel. I have never updated the C-Map chip from 6 yrs ago, but it always has shown position pretty much where it should be. What would have happened in just a few months to affect the accuracy? Anyone have any ideas what might be the problem?
did you check the offset setting? if it's been messed with, your chart will be off and no longer where it's supposed to be. same with the datum setting.
next, check if it's an accuracy issue with the GPS sensor by comparing the coord. with another GPS.
And then call our Customer Care Department for a chart card update - it's really OLD!
Do you have WAAS enabled? If not, your accuracy is only within about 20 yards. What did your GPS say that the Estimated Position Error (EPE) was? Maybe that's the best precision that you can obtain in that area. Old chart and wrong datum are also possibilities.
Your constellation at that time may not have been robust enough at that time and in that location for the accuracy you are looking for. You have to check a PRAIM (predictive receiver autonomous integricty monitoring) program to check the constellation geometry is sufficient for your desired operation. In addition, there are some activities right now in Florida that may degrade your GPS integrity. Always best to check the nav notices if you are going to rely heavily.
http://www.navcen.uscg.gov/
http://www.navcen.uscg.gov/gps/gpsnotices/GPS_Interference.pdf
As previously noted, check your datum setting first, check your sat reception quality, check any offsets and check your nav notices. That said, without using a PRAIM program, and using the time and place, we don't know the quality of your constellation which at times may not be what you need.
Wow thanks for all the input. I'll try to reply in chronological order. When I got it back from Northstar, it seemed the charted position at the dock was different from what it had been previously. I adjusted what I believe Pascal refers to as the offset to place the position to where it should be relative to the chart. I found that under cruise, it was not tracking where it should be-channels and channel markers were off, so I reset it back to the default. It seemed to track correctly after that except for the position at the dock. I cannot recall whether I played with the datum setting or not. Is that something that needs to be updated from time to time? Everything seemed normal the last time I had it out which was several weeks prior to my latest cruise. I boat just north of Tampa Bay-mostly in the intracoastal at Boca Ciega Bay and behind the barrier islands. The channels haven't changed much in all the years I've been boating there. Amy, could an old chip suddenly begin to read off in a chartplotter? GeeBee-what you said sounds impressive as hell but I am totally clueless as to what you said. Greg isn't the only one that had it go right over his head. On those links, most deviation(?) in the Florida area was on the east coast. MacDill AFB is perhaps 10-12 NM from where I was but dunno why they would have been degrading the accuracy on a late afternoon/early evening shortly after xmas but I guess anything is possible. At least I have some things to look at. Thanks guys.
You datum should match what your chart datum is. In most cases, but not always it is WGS 84 (World Geodetic Survey 1984). The chart datum is important because the world is not a sphere, it is not even an elliptoid, it is a lumpoid. WGS 84 makes a number of compromises that while not 100% accurate are good enough for high order nav accuracy. If you look on your charts or the documentation with your chart chip it will tell you which map datum is used. The datum you have set on your GPS should match the datum on your chip.
May I suggest "How to Read a Nautical Chart" by Nigel Calder? One of the better books I have read and explains map datums in detail.
Finally, simply put, with respect to GPS, there is selective dithering of the signal for security purposes and those are noted in the nav notices link. There are also times when the geometry of the sats is such that you cannot get a really good resolution of your position (because the sats are not in stationary orbit) These situations usually last only 15 minutes or so but there are times when the best you can expect based on sat geometry is about .5 nm guarateed. To figure out those times, you need software to calculate it. So to be 20 yards off is not that much if you have bad sat geometry.
If you haven't updated the chart card, then it should not change. The waypoints, however, are stored in the plotter memory, not on the chart card (which is read-only). You say they did a software upgrade? Were your routes backed up on a memory card or did they save and restore them after the s/w upgrade? Generally, a s/w upgrade will wipe out the saved routes.
I'm with the other guys on rechecking your datum. Generally we convert our charts to WGS84 if they are not already. Software upgrades can reset some settings. Have you spoken to them about defaults that may have changed?
Thanks for an explanation I can understand GeeBee. When I got the plotter back, all my routes had been deleted so I had to start from scratch. Thruout the summer, everything seemed to be tracking fine-always positioned on the chart to where I was in realtime. The only error I noted was the at-dock position. I will check the datum setting this weekend when I go down to the boat, but I believe the datum setting was the WGS84-I do not think I changed that, but I do remember checking the setting. Everything was reading accurately until just my last outing a few weeks back. Perhaps the geommetry was off like GeeBee said. I'll be checking the tracking and report back what I find. Amy, what is the charge to update a chip?
You might try the following:
Turn on "mouse droppings" ( leave a dotted line track ), and leave the unit on, while sitting at the dock, for an hour or so. By the end of an hour, a couple of things should have occurred: The number of satelites available may have varied, hopefully, the number will have increased, at some point, and also, the track left should be "contained within the error allowable" and give you a visual average, over time. The center of the "blob" of track should be pretty close to your actual position.
( easier to do, than to describe! )
You can update that NT+ Wide card for $89. You can also get a memory card to back up your routes outside the plotter.
There should be no need to check the datum for your charts. The vast majority of charts used in the U.S. are based on the Clark 1876 datum, which is for all intents identical to WGS-84. The differences between the two are less than a couple of meters.
The huge errors that GeeBee mentions were possible during the initial phases of GPS use several years (when the full compliment of satellites were not available) and if you do polar navigation. They are extremely unlikely in your case.
From someone who uses GPS systems on a daily basis to get accuracies of much less than a meter I can confidently tell you that the overall GPS system is not the problem. Unless you are operating in areas where the signal is intentionally degraded for military training or for GPS testing you will not get big errors. The intentional degradation GeeBee mentions (called Selective Availability) was turn off over 10 years ago and has never been used again.
Your problems are almost certainly bad chart data or incorrect use of the offset function.
