GPS/Chartplotter under $500
dvanvleet
I am trying to find a good GPS/Charplotter, with built-in antenna, for my boat. I mostly boat inland lakes, but in the coming years, who knows. I am trying to stay in the under $500 range. One that I came across, that got good reveiws, was the Eagle Intellimap 502c iGPS Color Chartplotter. Thoughts/recommendations?
The Eagle units are the stripped down version on the Lowrance units. Basically its the same exact unit as the Lowrance but without the bells and whistles. I recommend going with the Lowrance if possible because they have some really nice features. I currently own the LMS-337c and the LCX-37C. I think yiou might find some nice Garmin units in that price range.
I forgot, I have also looked at the Lowrance GlobalMap 5300C iGPS. This one seems to get good reviews too; anyone own one that has experience with it?
i like Garmins, their interface is very intuitive and the new chips with sat pix are really nice. I recently used a 525, it's a little outside your budget (about $800 from boat fix) but nice unit. Smallish screen but easy to read, easy to use.
although they have eliminated the "quit" button which was real handy when you scroll and quickly want to return to the boat position. you now have to press two buttons to get back.
i've always been a fan of garmins, they are easy to use, even the more advanced functions dont' require pulling out th manual to figure out what the developpers where thinking... :-)
I find the Lowrance tends to be sounder with GPS added, whereas Garmin or Furuno are GPS with sounder added. (make sense...?) I bought a Garmin 420s for $475 at the Vancouver Boat Show - it will serve my needs fine since I'm not using the chartplotter feature much, if at all (since it's another $300 or so for the charts!)
One option if you have a laptop is get a cheap handheld GPS like an eTrex, then plug it into your laptop and run Nobeltec. In fact, if you're in the US, you can get BSB charts for free and run OxiExplorer, which is about $60 or so. Total cost (not including laptop) is under $200, and you get charts displayed on a huge, high-res screen that can also play movies ;)
druid
Depends on the boat... most laptops are unreadable outside and even in a pilot house can be hard to read on a bright day. You also have the issue of spray and rain if you're even considering using one outside.
Agree w/Pascal on the laptop issue. Heat and vibration are the enemies of laptops on boats. We've burnt out two laptops (1 Sony & 1 Toshiba) that way. The biggest drawback to using the laptop is they're too bright at night. I tried a couple of optical gels to cut down on the brightness but still not enough. Unless you go to a MIL spec laptop w/ruggedized hard drives, ability to turn down the brightness and extra cooling you'll probably be disappointed. I also like the Garmins (have 2). Just picked up the 540s for under $600. The G2charts are a lil' pricy though at $240. I think the 400 series Garmins are in your price range.
navman 5500 is not bad and is in your price range as well...
dave
I'm really leaning towards the Lowrance GlobalMap 5300C iGPS because I like the larger display and I found where I can get it for about $330 new.
I have the precursesor to the Lowrance 5300 and after 5 years it is working very well. Navionics lake charts are good. I also have newer Lowrance, Standard Horizon and Garmin. Agree that Garmin is the easiest to use.
I use a laptop on my 34c with a sunvisor and it works very well.
Laptop mounting systems are available from www.emount.com or www.ram-mount.com. There should be no vibration with these systems. The program I use is an entry level program ($150) called Tiki-navigator. (www.tiki-navigator.com) It's very user friendly and doesn't have the bells and whistles that you don't need anyway. Do you really need to intergrate your AIS and radar, with weather downloads, onto your laptop? They totally got away from the usually Windows interface and designed the program so it can be used at sea with ease, and it works! No pulldown menus! Log onto the webite and download it for free for a trial period. You can also download all the charts you need for free from Maptech. Try it! The screen on my Garmin chartplotter is just plain too small! I use it as a back up unit.
I believe lowrance uses one data card for the US opposed to the Garmin where you need a card for each area you boat in. Those cards can get pricey!
Doug
I just bought a Standard Horizon CP-180 and the card for the northeast from Boatfix. Total (I think) was right around $540.00. Haven't had it on the boat yet but do have it powered up here at the house and it looks as though it's gonna be just fine.
The Lowrance Freedom map, is only the coast line--not inland lakes. You can get Lowrance (Navionics) lake charts. There are some hard drive units which also have the lakes on the hard drive, as some of the plotters have the coastal areas on the hard drive. Some Lowrance units have both the coastal and lakes on the hard drives.
"Im selling new standard horizon CP-180 on e-bay 850.00 unit for 439.00"
" 850.00 unit for 439.00"
Better get it quick. Even the $439.00 is more than it costs at Boatfix
We sell them, brand new, for $414
http://www.boatfix.com/cart2/Scripts/prodView.asp?idproduct=6428
I keep telling you guys to stay away from Ebay. Here's what the ad says:
* 50% off
* 2 day proirity shipping
* Dont wait price is going up
* You watch it you will loose it this is an incredible deal
* 1-3 day delivery Fast Fast
Retail is 899.00
Thats 60% off prices go up as season approaches
Aside from the spelling, the unit is being discontinued. Prices won't go up "as the season approaches." The list on the unit was never $899. He's got a "buy it now" price of $469 - a full $50 higher than BoatFix sells it for. As noted above, this is not much of an "incredible deal."
Gee thanks Les......NOW ya tell me that I just bought a (actually TWO of them)
unit that's going to be discontinued.....lol.....Just kidding...Just because an item gets discontinued doesn't make it bad. I'm sure this unit will work just fine for years to come.
* 50% off
Here's one you're better off to watch and lose on.....
Interesting, that Standard Horizon's looks interesting. There are just too many choices! Just to level set, I'm will mostly use it on inland lakes in the Southeast so which would be the best for this? The Standard Horizon?
