Hard Restarting
fav1
After running the boat for about 45mins.-1hr, shutting it down, and then trying to restart it after about an hour, it wouldn't start. I finally got it started by spraying a little starting fluid in the carberator.
It did start right up the first time in the morning before I took it out. Also, after finally getting back to the dock, I shut it down, and tried to start it right up again, and it started. It seems that after running it, and then letting it sit a while, is when it has trouble starting. Any ideas.
Sounds like "vapor lock". Try cooling the ER down by running the blowers for awhile and see if that makes a difference.
It'd be a big help if you'd tell us what Make/Year/Model you are referring to. Is it in fact carbureted? Some of us have EFI and some of those confuse the Throttle Body with a Carburetor. Makes a difference in troubleshooting.
Should have included this info. It is a 1996 5.7l Merc., carbureted.
I had a 1990 5.7 carb that did the same thing, I never got it to stop doing that for the 3 years I owned the boat. It always started but you really had to work at it if you wanted to hot start the motor. Cold it fired right up, Please post if you find out what is causing it.
Had the same problem - vapor lock. Added TWO additional blowers rigged to push cool air from outside toward carbs to keep cooler. Reduced carb temps by 35 degrees after a 1 hour shutdown and allowed easy restarts.
Delaware Jim
