Hatteras 53
Jim J
Can someone give me a quick breakdown of the varuious floor plans available on the Hatteras 53s for the years 1970 to 1989. I see "extended deck" "aft", cockpit yachtfish, stabilized, etc...
I'm not intersted in the offshore tournament fishing versions.
Is there a good place to go to study these floor plans?
a copy of powerboat reports should have a bried description of both
the "standard" 53MY is a flush deck with 3 staterooms and galley/dinette below and split (by a companionway) walk in ERs. The big difference with other flush decks (Chris, bertram, etc...) is that the helm/saloon aft deck is on the same level as the deck which gives more room, better view, more privacy. on the downside, it makes for a sligtly taller boat.
variations are the 53 Yachtfish, same hull but with a cockpit instead of an aft deck and with only 2 stateroom (I think... there might have been a 3 SR version)
The ED has the saloon extended to the gunwhales instead of having the wide walk around. more room inside but you loose a lot of ventilation to the aft deck (that's a big deal if you use the boat in hot climate as the aft deck gets a lot of air thru the wing doors), I've been on ED boats and the difference is huge... You also loose the ability to walk around for docking although that's not a big deal since you can go to the stern thru the saloon yet still access your spring lines thru the side doors.
other versions to consider woudl be the 56 and 58 which are very similar boats. the 56 started in the early 80s i think and has almost 2 feet more beam which makes a huge difference. the 58 came in various versions, including a yacthfish which is probably the best of both world... the 3 stateroom, a smaller but still usable aft deck AND a cockpit. there was also a 58 MY (no cockpit) with galley up and 4 stateroom. They are pretty rare and very nice boats (the galley up and enclosed pilothouse is nice) but the aft deck is smaller and hot because of the extended deckhouse.
stabilized means the boat has stabilizers (hydraulic active fins) which significantly reduce roll. they're expensive... 30 to 40k to install so stabilized boats will usually sell for more $ (everythign else being equal) but you loose about a knot or so
engines are the other significant difference... most 53s (and 58s) have DD 8V71s which are very reliable. earlier boats had naturals and will not get on plane. most 73/74 and up have TIs (turbo intercooled 435hp) and will get on plane, just, cruising aroudn 16 17kts. they burn 35 to 40pgh though whereas the naturals will sip jsut about 10gph at 9kts hull speed... and cost less to maintain.
browse yachtworld to see what's out there... also hatterasowners.com has library full of online brochures.
Later models, somewhere from early 80's onward may have 6V92's. (the later the model, the more likely it is that you'll see 92's)
92's don't enjoy the same reputation as the 71's, but I'm not scared of them, especially if they're treated kindly as Pascal suggested. My neighbor has a late 80's-vintage yacht fish. He cruises her as a displacement hull and has several thousand hours on his 92's w/o issue.
Sometime just before 1980, the facia of the bridge was rounded off, instead of the "3-panel" look of the early models. (Pascal, do you know the exact year of the switch?) Since relatively few changes were made, that particular feature can help identify an early model from a late model from a distince.
i don't remember any change to the bridge outer fiberglass. the windshield was changed from the 3 panel alum framed to a venturi styled plexiglass with grab rail, that was arond 74/75
the wider beam 56 adn also the 58MY (galley up/pilot house) have a rounded corner lower windshield...
there were very few changes to the 53 over the years... around 74/75 they replaced the 3 small transom portlight with two large hatches and removed the overhead escape hatch. they also reduced the size of the master head to add an extra shower stall (ealier model hav a shared shower between both aft heads.. which i prefer since the master head is much bigger)
als0 minor variations over the years to the bridge layout.. early boats had just a small center pod.. mine has a full width helm forward. boats with venturi winshield have a center helm with a seat forward of the helm...
but that was it... very little changes over the years...
the big visual clues are the ventury windshield and the 2 larger hatches on the transom
This is probably more granular information than Jim wanted, but I'm stuck in the office waiting for a severe storm to pass...
From the boats I can find on the net, the rounded bridge and venturi windshield started after '76, in or after '77. (I couldn't find a '77 to pin it down)
it's hard to pinpoint as some boats have been retrofitted with later flybridges... I've seen 73s or 74s with the venturi WS and center helm.
if someone went through the trouble to put a later bridge on an earlier boat, I'd suspect it was part of a larger effort to stiffen the bridge floor once the core was compromised. (that area was vulnerable to softness I THINK through the entire production line)
I might be getting various neighbors confused, but I'm pretty sure the guy w/ the '87 had a problem with a soft bridge floor.
not unless holes were drilled and water got in the core... like any deck.
You guys are the best. This is exactly what I was looking for and no, no level of detail is too much at this point of my search. I am currently in a 36 Aft cabin Carver and very happy with it as a weekend crusier and usually make a couple of week long cruises per year.
That boat has taught me a lot overr the years and this site does a GREAT job of filling in the blanks.
My future plan includes a bigger boat (go figure) and the 53 seemed like an excellent choice given the inteerior space, dependability and overall quality.
I'm not 100% locked into this make or model, but I wanted to get as much info as possible now so I can fine tune my expectations when the serious search for a replacement begins.
Thanks for all the input
Pascal,
I just got back from the owners site, thank you sooo much for that connection. The insight you gave regarding the affect on the breeze to the aft deck on the ED version is of great value I wouldn't expect anywhere but here.
Thanks again
i knew before i got he boat that the large aft deck was probably the place where i'd spend a lot of time but didnt realize how much ventilation the wing doors woudl provide. Even in summer time, and i'm talking florida..., even jsut a 5kts breeze makes the aft deck comfortable when on the hook. the main saloon also has a lot ov ventilation with the side doors and opening windows... again, we usually dont' run the AC during the day when anchored as there is no need to.
another big advnatage from the higher saloon is the view and privacy. you are much higher than most boats and people eyes on most docks...
few boats have that true flush deck layout. There are a few vikings but most Betrams and CCs have the saloon a few steps down from the main deck.
