head conversion
celliott
I have a 1996 Crownline 250cr cruiser. I has a manual head onboard. I would like to convert to a electric head. Can you see any problems with the conversion? Can i keep all the plumbing?
I don't know your specific vessel, but I converted my manual Jabsco head to a Vacuflush head on mine and was able to reuse much of the existing plumbing. The biggest decision, other than making sure the new head will fit properly, will be whether or not to use fresh water or raw water since many of the electric head models can be either fresh or raw. I assume your manual head is configured to use raw water as most are. The Vacuflush I installed only used fresh water, so I had to tee into my pressurized water system to provide the flush water for the head. This was very easy to do and the discharge hoses from the manual head were a direct fit to the new Vacuflush head. You will need to make sure you can orientate the water supply and discharge fittings on the base on the new electric head to match your existing plumbing, but my understanding is that most models will allow you to rotate the base to re-orientate the fittings according to your needs.
I am going the other way from electric to manual. Smaller boat 28' and want the simplicity and electric motor is having problems. Make sure that you have a good electrical set up for the electric head, properly sized wire and an adequate circuit. They draw a fair amount of power, I would want it on its own circuit. Mine is tied into some other stuff and I am sure it doesn't help.
An electric head doesn't use that much power in the grand scheme of things but when it does run it needs AMPS! I used 10 ga wire, and until I removed it the macerator shared the circuit (they were never both on at the same time). Otherwise a dedicated circuit is a good plan.
IMO an electric head (once installed) needs less maintenance than a manual (I've had both)... and for sure the ladies like it better. The price tag will certainly get your attention, though.
On the off chance it's a Raritan PHII , they do offer a easy kit (likely available through BoatFix ) to upgrade to electric PHEII. As Willie mentions above , make certain to properly size the marine elect. cable , momentary switch and breaker to handle the temporary fairly large draw.
Celliott,
My old boat (bayliner 285) had a Jabsco manual head, new boat (Larson 310) had a Jabsco 37010 Electric.
We seriously considered going back to a Manual head on the new boat. We found that;
1/ Electric is noisy, esp. at night !
2/ Low batteries mean you can't use the head ! especially bad early in the morning after running Anchor light all night. If you can't run a generator to recharge batts you are in trouble, or you will have to use your cranking battery to use the toilet.
3/ Admirals & Guests tend to give the electics a bigger flush - holding tank fills up much-much quicker.
In the end, we converted to the Jabsco Quiet Flush electric (and a third battery) ,..reasonably happy,... but I still wouldn't write-off a manual head !
I bought a macerator pump system for around $180 that bolted up to my original head in place of the manual pump. Came with fittings and with some maneuvering hooked up to my existing plumbing. Works well but as mentioned above it does require a large gauge wire or short distance from the power source to get it to work. I finally decided to just install a dedicated head battery which I'll periodically manually recharge.
ELECTRIC HEADS ARE LOUD!! Sorry, had to shout over the head noise.
