Head oder found the hard way
ctcruiser
Well as some of you may know I had a head oder problem in my engine room when someone flushed and I checked high and low and all seemed fine. Well today I found it the hard way. Last week I wanted to pump out because I knew I was near full but my wife in a rush to go home said just do it next week as she did not want to wait for the pumpout boat. Well we sleeped on the boat last night and she used the head this morning and flushed it about five minutes later their was an oder on the deck that faded in and out. I said to my wife some one around here must be getting puped out but then the oder came again I opened my hatch and instantly knew the oder was our boat upon closer inspection I could see a puddle and it it turned out to be liquid from the holding tank. [:-crazy] What a clean up nightmare the only thing good I thought was it would help me find the problem I checked the tank hoses and no sign of any liqued leak. then I saw a damp spot on the top of the tank checked it agin for crack but nothing. On the top of the tank is my macerator pump that I have never used. well guess what the hose coming from the tank to the macerator was driping where the hose conected to the macerator. The hose was so loose that it could could easly just slip it right off. I never even thought to look at it because it was mounted on a board at the top of the tank and I never used it. I double clamped it and all is good but the clean up was mess and I think that smell is burned in my nose because I sware I keep smelling it though my wife says she now smells nothing.
how about the wife who insisted on flushing doing the cleaning
If you haven't done so already I would suggest pouring some licquid bleach into the bilge just to make certain you kill all the bacteria.
Bleach should go last. Unfortunately I gained some experience in this department at one point.
First get it cleaned up best you can. Then go buy some KO. It's now a raritan product that Peggy Hall had put together years back. It's basically a concentrated version of the enzyme stuff that you put down on pet stains such as natures miracle. Throw a bottle of that down in the area and within a day or two (my experience) it will get into all the nooks and crannies and literally eat any remaining bad stuff. Trust me, do this step. It works wonders.
Then you can go back with the bleach, which is not a horrible idea, but the bleach products come LAST. I don't mean last resort, I just mean ordered last. The bleach will kill everything, good or bad. It will kill the bad bacteria and the good enzymes indiscriminately. So, let the enzymes do their good before killing them.
update: well after going back to the boat there is still a bit of an oder in the cabin not so much the engine compartment. I traced it down and I think the oder is coming from a wire chase that goes to the engine room right next to the holding tank. I cleaned up everything 3 times over the only spot I can not get to is behind the holding tank I have no idea if their is anything back their but if I had to guess their might be a little. any idea on what I can do to get back their taking the holding tank out is not really an option as it would require someone from the yard doing it(and i still may need to do this) because it is in a very tight spot. Is their a liquid I can put back their that will not damage wires ect.. I am going to go down again but things are more dfficult now because I slipped and fell on the engine and caught my self with my arm a nearly knocked my sholder out of the socket so my shoulder is very sore. right now I have everything opened up I am hoping the air will dry anything I may have missed and once it airs out I hope the slight remaining smell will go. I should mention that the liquid from the holding tank never actully made it to my bilge area. just on the side of the tank.
try flushing it heavily with water get your hose nozzle in all the nooks then spray simple green or such all over and scrub any areas you can then flush with lots of water again. If that fails there is some odor eating stuff at pet stores.
now you can delete your other post
You better believe Ghost has it. (Don't ask me why!) Just do it! ;-(
And just keep in mind chlorine bleach is corrosive to at least some metals like aluminum,and some caulks/bedding , rubber & wood. If you use bleach down there you might want to add a little vinegar after rinsing to neutralize.
Ghost is correct. Start with the KO then, maybe the next weekend or so, go to the bleach if any orders persist. Let the bleach sit and do its job for 24 hours then flush everything our with clean water.
