Heading North....
Yes, Pascal, I was heading north 3 or 4 years ago in the channel before Haulover inlet, and wacked something hard, so did the 46 footer that was running with me. No damage for me, drawing three feet, just a nasty sound hitting the lower skeg at 5 knots. But, same hit and a resultant slight prop vibration on the 46 drawing about 4 feet. Must be a sunken can buoy etc., perhaps it gets moved around in the tides and shifting sands.
Location is below beer can island, and we were on a low tide. I assume that was the same spot for you Pascal?
Pascal here is probably one of the best prop shops in the country.
Accu Tech Marine Propeller. INC
121 Lafayette Rd #3
North Hampton, NH 03862
603-964-3682
Larry the owner is very active on boatdiesel and is on the board of the national propeller association or something like that. I have not had much luck with Frank and Jimmy and since you are going north I would talk to Larry, he is very nice and knows his stuff!
Cor
I'll first state my ignorance and say that I know nothing about boating the ICW. But given the problems with skinny water stated in this thread, why don't more boats run out in the Atlantic? Especially a boat like Charmer, which can be out there on all but the nastiest of days.
Pascal - If it's any help and if you end up with Accu Tech, they're not far from me and I'm frequently in Rhode Island so I can transport them for you Newport/North Hampton or vice versa.
Without a stabalized boat running in anything with 4 to 6 foot seas is not fun for the crew or the boat. Even a boat the size of Charmer's is safer on the inside meaning you might have a few less sea sick people on board and less lose items on the floor. The boat can take the pounding but the Captain has to consider the passengers and cargo.
On most deliveries, if the weather is right, you do tend to run offshore quite a bit. In fact on larger boats it's common to run 24/7 offshore.
Apparently Charmer has no stabilizers so that limits it even more on what kind of seas it can handle safely and comfortably. Even at 70' in length.
"Even a boat the size of Charmer's is safer on the inside meaning you might have a few less sea sick people on board and less lose items on the floor."
On a payed delivery, you shouldn't have any sea sick people on board. :-)
And lose items should get stowed even if you're running on the inside. You never know when you'll get passed by some idiot who doesn't know enough to slow down and hits you from behind with a large wake. Without stabilizers that can mess up the interior of even a 70 footer real quickly.
Here's a product we use to hold items down to lessen the need to put everything away while underway. The stuff works great. Even in some very rough seas.
http://quakehold.com/collectibles.html
Thanks for clarifying what I was trying to say Captain Bill.
Years ago my than boss had a 105 foot broward and the captain was running the boat outside in some rough weather bringing it north. They ended up tearing open a bulkhead and taking on water. They managed to get back inside and saved the boat, 70,.. 100,..150 foot it does not matter once out in big open water it is still a tub not an oceanliner. As far as having things put away, the salon tv was on a lift and it ripped out of its cabinet and went flying across the salon!
Charmer was build by the same yard as my boat and I know this yard builds a good strong boat but still you should not go looking for trouble, better a day late than not getting there at all.
Cor
it depends on the boat really, without stabilizers it's just a PITA and it's also rougher on the boat, even with every thing stowed (indeed standard procedure whenever we leave the dock).
The last time i was close to being sea sick was 20 years ago changing an alternator belt in a hot engine compartment in 6 footers with my throat below my stomach... so sea sickness isnt' a factor.
running 24/7 is fine on a delivery when you have a crew, I don't. The two guys i have on board are more guests than crew and while they help out with lines and things, it's another thing to stand watch.
this is more a relocation than a true delivery anyway, part of my job is also to manage the boat and the costs. Overall running slower inside is cheaper than outside, at higher speed or with a real crew capable of maintaining a watch.
I anchored off Belhaven but the breakwater isn't much of a breakwater and wasn't doing much to break the chop created by the 20kts winds. So we moved up the Pungo and anchored on the south side with better protection.
tomorrow coinjock and norfolk on friday night.
Pacal,
If you're on the inside just south of Manteo, until you've passed it, be careful, there's some way skinny water there. (At least there was 2 years ago when I passed through.)
Got to use my Boat US tow card first and only time there, on my journey from Delray to Michigan City, IN. Dead center mid-channel yet.
I'm enjoying your trip by proxy......
Safe Journey
Tom D.
Hot Tomolly
76' Lazzara
(Enjoying my new TRAC digital stab's... woohooo!)
I have a heavy, stabilized boat. Sea characteristics and direction are a larger factor in comfort than mere size. Also, keep in mind that stabilizers control roll; you still have yaw, pitch and heave to deal with.
The ICW is a beautiful destination in and of itself. I would never bypass it unless necessary, or on whim. It is easily navigable if you play the tides. If you are in a hurry to get from Point A to Point B, drive or fly, IMO. We like to cruise around 9 knots or so. I just went through "planning" or northward trip for this year, and I am under some time pressure this time. I only pick up a day or two out of 14 by going outside from Ft. Lauderdale to New Bern NC, if conditions are right. It is just the wife and I, and 10, maybe 12 hour days are our comfort limit. Yes, we will go outside in a few more places than usual this time, conditions permitting. But I just can't bring myself to miss some of the beautiful stretches in GA and SC.
George
Cor
Sounds like the captain was either caught out or didn't pay attention to the weather forecast.
I don't think anybody is advocating going offshore in bad weather to try and save time.
"Tom D.
Hot Tomolly
76' Lazzara
(Enjoying my new TRAC digital stab's... woohooo!)"
I take it you replaced your Gyro Gales? :-)
Yaw, pitch and heave. Geo isn't heave a by-product?
By the way 12 hour days in a boat imply a certain level of comfort is present that reduces strain. For example yesterday we traveled from TwoWay Fish Camp to Isle of Hope. The day was hot and without a breeze for the most part. As a result biting horse flies were EVERYWHERE. We had to keep the bridge enclosed or face the constant attack of those voracious crites. In 85 degree heat that made the bridge extremely hot. We were driking cold sodas every half hour.
We traveled about 8 hours in that environment and it was a stretch to get this far IMHO.
If you plan to travel at a pace of 10 or 12 hours a day, make sure your boat is going to keep you comfortable and, you have help managing the boat.
FYI the water along that stretch was ok at high tide with only a few places at 8 feet under the transducer. We hit Hell Gate at dead low tide. Yes as Geo has indicated I am an expert at planning skinny water passages. Actually we thought we would be on a rising tide when we arrived but we left a half hour early and made very good time. But we bumped in and out of gear managing to keep at least 3.5 feet under the transducer, and they are dredging the channel.
It sure would help if people added more details about locations for those of us who dont immediately know where Twoway fish camp and Hazzard river etc. are located
Capt bill1 the captain gave in under pressure of the owner who thought his boat could handle the rough without any problem. After the trip north and back south to Florida the owner sold the broward and stuck with his 67' sports fish.
Cor
Google Earth is darn good at bringing you into these places as is maps.google.com
From maps.google.com -> link
