Could be stapled, nailed, screwed or glued too. If you can't find out from the mfg or dealer, I would carefully investigate an area which is not obvious in case your investigation causes any damage.
Be sure you have all of the hatches open and if possible bring a fan with you to remove the fumes from the glue. I just used the 3M spray glue and without a doubt I lost more than a few brain cells and not the way I like for them to go!
