Help...GPS Module not Responding
  • Thread starter Thread starter UB
  • Start date Start date
UB
Morning folks,
I know this is going to be very vague but I was wondering if anyone had any ideas about this. On the 4th of July, we were out watching fireworks on LI Sound. We were on the anchor with the engine off and the GPS (Lowrance LMS335) on. Very strong current that night and I wanted to make sure we weren't drifting. Out of nowhere, the unit beeps and displays "GPS module not responding". Ever since then, I can't get it to work. The sonar still works fine but no GPS.
Again, I know it's vague, but I was wondering if anyone had any ideas. I've checked the cable from the receiving unit to the display unit and also checked all of the cables in the back of the unit. I also checked all the pins in the cables and none of them appear to be bent.
Thanks...UB
Is there some kind of "reset" option on the unit? Might be one of those small access holes that you need a paper clip or pen-point to push in.
Maybe your GPS just died. I think I saw on the Lowrance site that it is a discontinued unit.
Pad...not sure what you're asking
John...I'll check the unit this afternoon
Thanks!!
Does the unit use an external GPS antenna? If so it sounds as if it might be a bad connection between your GPS and it's external antenna.
If mine gets blasted by my radar (or someone else who is too close) it will give the same message. Disconnect the power cable for 30 sec. Reconnect and cross fingers.
Sorry for the delay in getting back to this post.
- Don't see any reset hole. I even looked under the memory card.
- There is an external antenna. I checked all of the connections again and everything looks fine.
- I went to the Lowrance site and I see that they have a software download available for my unit. The latest software version is 1.7.0 and my unit is still using the original version 1.0.0.
I did notice something unusual though today. One of the "pages" that you can bring up on the screen is "Satellites". This screen normally shows you a row of something like 10 satellites, and how many of them you are connecting with. Right now, it is not showing me the row of satellites. It's like the unit is not even looking for them. I would think that even if the problem was between the unit and the antenna, the unit would still be trying to link up with the satellites but not be able to.
UB
Have you run through the procedure given on the Lowrance Troubleshooting page?
This page also gives the soft and hard resets for various units.
( soft reset retains user data such as waypoints and tracks. Hard resets nukes user data... )
I had this same exact problem with my Lowrance Global Map 3000MT and it turned out to be the antenna (LGC-12S) had just died (apparently they just do that).
hth
Jeff
We had a Lowrance 3500 and currently a 7600. Both have/had a separate power source for the exterior antenna. Check to make sure the antenna power source is ok. Lowrance told me on the 3500 that I had a bad antenna when it turned out the power lead had broken.
Is there anything else on the NEMA 2000 network that the GPS antenna is connected to? If so, could be a termination problem.
Next time this happens, unplug and plug back in the NEMA 2000 network connector on the back of your GPS and see if it starts responding. I have similar issues.
There's nothing else connected to the NEMA network. Every time I get off the boat, the unit comes with me so it is constantly getting disconnected and re-connected. Since the unit powers up fine, I'll have to check the power for the antenna.
As I stated earlier, I just find it strange that the unit doesn't even seem to be looking for the satellites.
UB
Two possibilities. I've had this message before, and corrected it by merely unplugging the hockey puck,and reconnecting it. First do your normal power off, then the plug that goes from the puck to the back of the screen display, I think there are two connectors. Just unplug and replug a couple times to make sure they self clean. Finally, the Hot lead for the GPS antenna is a separate connection. On the 355,(same unit I have works fine, differences were just number of dots in the screen display) you will need to find the thin red wire that supplies power. I doubt you lost power, but its worth a check.
Lastly, on the 355, if this is still the original unit and you have never had the hockey puck replaced, there was a recall. If a cruiser with highpower Radar went by or near you (in my case the other guy was about 100' away) it will have fried the puck. A call to Lowrance stating you purchased it originally, and this is the first time it happened and they will overnite you a new puck. (Least the did for me).
Post your results, I love my unit and insisted that the new boat had one or I would try another dealer. The new unit is now 525 and has a better shielded GPS antenna, and fancy screen display, but the guts are still the same. For me it is the user interface that sells this unit.
KKKKFL
Ya know, now that I think of it, right before it died, a police boat was circling us (at the time, I thought he was checking my reg stickers or something with his spotlight) and he must have been less than 25 feet from us. Circled me 2 or 3 times. Could his radar have fried me?
check the antenna cable from end to end. I had a similar problem with mine (garmin 2006c) last year, turned out to be the cable chaffing where it enters the antenna pole. whoever installed it didn't use the rubber groomer and pulled the cable to taught. 3 years later, one of the thin wire inside was cut/corroded.
i serioulsy doubt a boat radar 25' will affect your GPS...
I agree Pascal there is no way a radar operating at 5 times the frequency of a GPS amplified antenna could ever damage the GPS front end. Even if it was on the same arch on your boat and no way by a passing ship. I doubt it would even degrade the GPS ability to capture the satellite signals.
I would contact the manufacture and find out if you can do a master reset on the unit, you loose any saved data but it could be a glitch in the programming.
Regards Bill
BIllyIII, I guarantee you that on my boat if a) the GPS was not raised on it's stub mount and remained in the radar beam, and b) the radar was on, the GPS would fail miserably and report "NO FIX". Raising the GPS antenna head to where it was supposed to be fixed the problem. No Known permanent damage, but the radar definitely overloaded the GPS front end...
OTOH: at 25'+ range, it shouldn't have been an issue.
well, you're talking about to antennas next to another. that's one thing... I agree that the GPS antenna shoudln t be too close and on the same level.
but a passing boat radar will not affect your reception.
Spoke to Lowrance today. They are pretty sure that the problem is that I'm running software that is too old. It needs two updates but since I only have 1 memory card, I'll have to do it in two trips out to the boat.
I'll let you know what happens. Thanks everybody!!!
UB
Radio Bill; I agree with your statement about in the radar beam (pattern) effecting reception. My GPS primary and secondary (back up) are elevated above my radars antenna beamwidth. Take care. Bill
