ok so i have a really hard time with this gas tank issue and i need help and advice!
The boat is a 1995 silverton 361 express, two 140 gal tanks, twin engine, and gen.
someone smelled gas, marina moved boat from slip and called me. I went there the next day and found all my bilges full of gas. The mechanic is the one who moved it and seen which tank it was coming from. Said it was coming from bottom, said sides, front and top where dry. Fast forward through shutting off tank supply lines, cleaning and cleaning and cleaning for 2 weeks. Generator supply line comes from that tank so the mechanic and I decided I could remove supply line for engine and supply line for gen and union them together and supply gas from the other tank to the generator. Now assuming the tank has a hole in the bottom( keeping in mind the tanks were both replaced in 2001) I assumed it would be empty and sounded empty. The tank is tucked in a small space can't see much of it and no way to see in it. I removed the engine supply line and gen supply line and union them together, when I laid the newly unioned supply lines down gas drips on my hand from gen supply line… I unscrew it make sure there is not trash or anything at the barrel connection and I screw them back together. I shock the line and gas goes all over my hand and down my arm… I once again unscrew the line and take a flash light and look closely at the fitting and sure enough there is two splits in the barrel. Keep in mind this line is pouring gas in my hand with it screwed to the other line before I even turn on the supply to the line. I take the flash light and look at the tank closely and I can see gas staining coming down from that corner where the gen supply line was attached… it's at the corner and about 2-4 inches of staining on both the side and front all the way down to where the mechanic said it was coming from under the tank. I replaced the gen line and no leaks and is running perfect from the other tank. I ran a hose down the fill line and there IS gas still in that tank.. MY QUESTION IS… is it possible for that fitting to leak 20-30 gals of gas from the top of the tank. That line would have a dip style tube that runs to or close to the bottom of the tank. The generator does sit a little below the tank in the very back center of boat. The engine has a supply line and a return line and there is a vent line, all are on the top of the tank. About a week or two before this happened I did over fill the tank to the point I lost some gas out the vent however I ran the boat for a couple hours afterwards. Is it possible for gas to leak from the top of the tank at the fitting???
