My boat has an Onan MDKAU diesel generator that recently started up and shut down along with blinking light that indicated "no sea water being pumped." Boat was in water and exhaust was clearly visible prior to shutdown. After checking filters, etc, I found that I could pour water freely through the intake hose indicating that the sea water intake was not blocked so decide problem has to be impeller. I'm not a great mechanic but have changed a water pump on an old car so I figure that I can do the replacement myself. The part no. is printed on top of the generator so no problem there. I don't have an operators manual so went through a maze of Onan web sites to try to get one or at least a photo/illust on how to replace the impeller. The water pump for the coolant system is perfectly obvious. . . but the location of the sea water impeller is not.
After an exasperating week of searching I have a regional dist. guy supposedly researching what it is that I need to do the job. He said he would call back so that we could complete the order. . . . . . . . He didn't say when. . . . another case of the NC syndrome. . . . subject for a new topic. Can any forum member help? Where do I look to begin?
