help please using "finesse-it"
booboo
Hi all. I need some help. I picked up some finesse it to use on my 3 year old boat. I want to clean up some of the very light oxidation before waxing. It is doing a bang up job. I am using a 2500 rpm 10" orbital buffer to apply a small 3 x 3 foot section at a time. I apply it evenly with light pressure as outlined on the instructions and TRY to hand buff it out but it is extremely hard to get off when applied. It is very fatiguing. I only did 25% of the hull yesterday. I was not even in sunlight but on the shaded side of the hull. Should it be this difficult to use. I apply it with a terrycloth bonnet on the buffer. What if anything am I doing wrong??
boo,
I usually stay out of these discussions becuase there are a lot of opinions out there and it's not that any are wrong, but it seems people find what works for them and then stick to it. I've painted and restored cars for decades so I'll share "my take" for what it's worth.
First, no- finesse should not be that hard to remove. 3M does offer a couple different products in the finesse-it line but thier functions are all very similar. Your problem isn't the product. I would bet your problem is how your doing it. Machine polishing compounds are designed with different grades of abrasives and, these abrasives are designed such that between the liquid carrier, the surface your polishing and the motion and heat generated by the polishing pad, the abrasives start out at certain "courseness" and they gradually break down and become "finer" producing a better shine as they are worked in and lifted off. Theres a balance that must be struck so that the compound does break down and begin to dry within a certain working window. If there is too much heat, the compound dries too fast, it stays in the course phase, perhaps burning through thin paint (not much of a problem on gel coat) and it doesn't break down properly and won't work as well as it should. I don't think this is your problem. If there is insufficient heat/working of the compound, such as from polishing by hand or with a very slow speed, it won't work right either.
It is not common to see random orbit polishers like your using (or the very popular porter cable RA polisher) used by professional body shops or detailers for buffing work. This is because this type of RA action is too mild for machine coumpounds. This is great to prevent novices from cutting through or burning paint, but it's really not well suited for working in machine compounds. For machine compounds, a 7" polisher with a good wool pad will work much better, but is also much more aggressive and should be used with caution, especially on cars. An inexperienced operator can do more harm than good in some cases. Because new gelcoat is so thick, it's not as much of a worry here but you should ask for a demo befor trying it yourself. The RA polisher like your using is great for applying final glaze and wax but it's not well suited to buffing with machine compounds.
The last peice of advice I can offer is to try "hand polish" with the RA. Hand polish is designed to break down with much less "working" and may work better.
Good Luck.
Yacht Brites Buff Magic has replace Finesse It in my book.
Finesse it can burn if you are not careful. Buff Magic doesn't burn easily.
Does a great job.
Jonathan
I just worked the forward part of my boat with Finesse polish. Then used Four Seasons wax (never used that before so I do not know yet how it works). I used a buffer and followed the West marine bonnet instructions. You can get a kit with four bonnets. I used the microfiber to polish, blue micro to apply wax, and the terry cloth to buff the wax.
It was much more difficule to work in Sun. But the Finesse did come off. Saved a lot on elbow grese using the buffer for wax and final buffing. The RA can leave some swirls so be careful.
my 2 cents
Hmmm....sounds like you're not applying and removing the product correctly. You should apply the product in a small area by hand first, not with the buffer. Then you need to use the buffer to work the product in the area. Don't let the Finesse It dry before buffing. If it's drying before buffing, you're doing too large of an area. Try working a smaller area about 1'x3'. Finesse It should not be hard to use if used this way. Good luck.
This past Saturday I Finessed and waxed a 36 foot hull in 7 hours. The result is spectacular. Worked with a helper who spelled me on the wheel when I got tired. Starting with a clean hull, we applied Finesse-it II with a clean white towell to an area approximately 5' x 7'. Using a rotary (not random orbit) buffer with a clean wool wheel, I wheeled out the 5 x 7 area well beyond the original compound application going side to side and up and down. I then overlapped the margins and did the same thing until the side was done. By extending the product with the wheel you really thin it out making it very easy to remove. Clean up is with clean white towells and takes about 10 minutes per side. I then changed the wool pad and put on another clean wool pad. I used the exact same procedure applying liberal amounts of Maguire Flagship wax with a white towell to a large area following by buffing it in. I spent about 5 hours doing the compound. The wax went on in 30 minutes per side. I spent another 1 hour detailing and wiping up residue from both sides of the boat and transom. My wheel is a 30 year old Black and Decker with the speed contol set to 1500 rpms. This prevents gel coat burning. Makita makes a very similar model today for around $280. BTW, this is the fastest I've done the boat as I had a strong helper. Last year my wife helped and it took 14 hours as I did all the buffing. Weather does not seem to effect the ease of application and product removal. Last year it was 40 degrees with a stiff wind off of Lake Michigan. This year it was 75 degrees and full sun. The product did well in both weather conditions. Finally, I followed up with 2 days of Advil. The pain is very nearly gone.
Makita 9227C, if memory serves me. Very nice wheel. Has a 'D' shaped handle which helps on the human wear thing. (Yeah, they get heavy after a few hulls).
A DA or orbital buffer isn't going to be terribly much use for gelcoat, unless perhaps you're just waxing. Then it's not really worth pushing the few pounds of machine around, dragging extension cords, moving scaffolding, when you can just carry a bottle, sponge and rag, and use a single ladder....
