help with power bill
Charlie
Last month we allegedly used 2564 KW of power on our boat while aboard for 2 weeks. We have 2 30 amp services both 110 v. Our power bill was $234. In the last 2 dayswe have used 419 KW and appear to be on our way to a $500 month. Is this even possible?? We have a 16000 btu AC and an 8000btu reverse cycle AC and a princess cook stove. What's going on? Oh yeah, our rate is .0913 per KW.
HELP
Get your meter checked, sounds like it is running fast.
Unplug your boat and see if the meter is still running. If it is, see who else your paying for. If it is not call the electric company. Tell them you want money back for last month too.
If you left both AC's on all month for 24 hrs your bill shouldn't be that much. In a month period the compressors wouldn't be on all the time. But if there were, here's a rough calculation:
watts X volts X hrs =KWH. Assuming they draw, lets say, 20 amps total. 120 volts X 20 Amps= 2400 watts X 24hrs= 57600 watt/hrs or 57.6 KWH/ day X 30 days = 1728 KWH X .0913 = $157.77
If the meter is ok, you can use a amprobe to check what each is drawing.
Yeah, I figured if we pulled the entire 50 amps 24/7 it would be:
50amps x24 hours = 1200 amps per day x110 volts= 132,000 watts per day divided by 1000 = 132kw per day x30 days = 3960 kw x .0913 per kw hour = $361.50 would be my max bill if I pulled max power 27/7. So I guess my math is right. We plugged into the transient power [with marina permission] and will run it for 3 days and recalculate the consumption from another meter. I hate it when this happens. If anybody checks my math and finds I'm in error, please sing out. Thanks.
impossible... get the marina or power company to check the meter. your math sounds right...
Thanks Pascal,Hogan and Gary. Needed a little confirmation.
Yeah right. I'd like to know how the conversation with the $7.50 per hour customer support rep goes. I can hear it now... "You killed a what?" ... "No kilowatt" ... "You wan't what?" ...
Please come back here and share the Kodak moment.
