help with steel bottom
loriedj
First time with steel bottom Houseboat...I can see rust on the steel sides...so I was wondering how to prep for bottom paint this spring ...sanding? primer? bottom paint? anything else
very low budget
I assume this is a HUGE job....need advice...
keep in mind 3 girls ..best friends own boat...we have lots of stuff... needed to go bigger..(I know men ...bigger is not always better.. ha ha ha)
(I haven't seen the bottom yet Just bought Houseboat 7 months ago)
Thanks Laurie
If you are going to use antifouling you will need a barrier coat as well. The copper and steel would make an electolytic cell and would cause corrosion.
You will possible need to sandblast the hull before priming. You might find some good information on some of the marine paint manufacturer's web sites. I think Interlux has some good notes.
I too have a steel boat. The best bottom job for a steel boat is to sandblast to white metal, then apply 2 coats of coal tar epoxy. The coal tar must be applied right after blasting, otherwise the metal will begin to rust immediately. Properly done, it will last for 5-7 years with haul-out and touch-up every 2 years. Coal tar epoxy is sold by Porter paints, and Sherwin Williams. You must thoroughly mix the 2 parts, then apply with stiff brush and heavy knapped rollers. Make sure you coat everything, including rudders. Avoid getting it on your anodes- or zincs.
Kahuna said it all. Also applies to aluminum hulls. Steel boats rust out from the inside. Replace any bad metal before even thinking of painting.
Laurie: this is heavy duty work requireing some experience to be sucessful. Consider finding a yard that works with steel frequently and see what they have to say.
Just how big is it??
3 Girls, huh!!? I work for free.:D
Ive coal tarred my hull-40', 3 times. It takes both hands to handle that filled roller. Most of it is done on your back, or in a low stooped condition. It WILL wear you out quickly. Wear clothing that you will dispose of because you can't avoid getting the stuff on you. You can clean up with any good solvent- mineral spirits or xylene. Any equipment you use you throw away. The sand blasting is very important. Any other prep method will not allow the coal tar epoxy to properly adhere to the surface- it will eventually flake off in large pieces. My boat requires about 5 gallons to cover the hull 1 coat. You generally have 8-16 hours to put the 2nd coat on. Figure about 250.00 for the materials and equipt.( for 1 coat)
