Hello all, hope things are going well. Just wanted to share a story. Yesterday was wake up day for CaliCat the 59. Her first winter outdoors, and my first winter shared with her.
After reinstalling the coolant hoses, adding a new thermostat, hooking up the battery, filling the tub with water, dropping the outdrive in, and hitting the switches, she roared to life!
Well not quite, actually she fired up then quit several times, Due to a bad choke, then stayed running. After attaining a steady idle the visual inspections began, and wouldn't ya know something odd popped up. No water from the outdrive tube, a sure sign of no flow! Yikes,
the manifolds are gettin hot too. Quick goose it a couple times to encourage further damage
because the temp gauge aint movin a bit, then shut it off. Yanking the thermostat cover revealed dry coolant passages. Touching the impeller pump houseing brought forth visions of puddles of melted rubber inside. In a moment of pure lunacy I decide to pour water directly into the thermostat opening so as to cool things off a bit while I ponder the resale value of an old boat with a fried engine. Secondary reason for shutdown was the nice puddle of gas forming on the intake manifold of a pistol hot engine caused by the leaking fuel filter hose. Replace thermostat cover, repair fuel hose, blot dry, and restart, Hurray it lives! Outdrive does excellent impersonation of female horse lubricating the lawn! Now if I could only get the river to drop a few feet.
Oh well, two out of three aint bad. Bye!!!
