hinging a radar arch
philmeup
Hello
Does anyone have ANY knowledge of hinging/lowering a radar arch on a 53ft Hatteras motoryacht ?
Thanks,Phil
Not on that specific boat but I have seen it many times in South Florida on other boats. I almost purchased a Searay 330 with one. That boat has an aluminum arch so the price was a little high for welding. Depending on what the arch is mad of will probably depend on who you get to do the job for you.
Usually a plate is either bolted or welded on--glass or aluminum arch. The there is a pin aft, with a beefy hinge, and same foreward. The foreward pin is pulled and the arch dropped aft.--you want a block and tackle or come-a-long to bring the arch up or down under control. You also have to be sure that the wires are long enough to allow the arch to come down.
Look up COUNTERPOINT - she's a 53 Hatteras somewhere near Nashville.
Was being surveyed recently at Rock Harbor, and hinged arch caught my attention.
(You double posted)
JHS
there is a 30' Seary w/ a custom arch. is has a pivot at aft of the mounting plate. It uses an electric actuator to lower. all controls from a keyed switch at the helm. really neat.
