Homemade windshield extension?
gcirillo
I've been thinking about making a simple 18" x 10" plexiglass panel that can be wing-nutted to the top lip (aluminum frame) of the existing windshield. I would probably have one side bolted/screwed semi-permanently with rubber washers, and the other side notched and held with a wingnut so that it could be swiveled and stowed without interfering with the canvas.
There's an aftermarket device that does this, but it uses an unnecessarily complex set of brackets.
The extension will save me from my usual Monday windburn!
Am I missing anything?
Is this going to be looked thru? If not as its to be used as a sun block, don't use plexy.
Anyway, as long as the pitch is flat enough you shouldn't be putting too much strain on the window frame.
It will be looked through, so it needs to be see-through. I just need a little something to deflect the wind blast over my head!
Ah! The old sun visor in-the-convertible ploy! Make sure you have the proper English driving cap, leather gloves and a scarf...;)
Seriously, however you mount it, make damned sure your screws miss the tempered glass in the frame channel...(one screw point in the glass, and bye-bye glass!) you don't want the inconvenience and expense trying to replace curved glass.
Funny you say that. I was wondering how far into the frame the glass extends. Any idea? Obviously, trial-and-error is not an option!
You have about a 1/16th inch leeway...maybe less, from the frame to the glass. The glass is usually seated in a U-shaped rubber seal that rides in the frame channel.
one way would be to take a feeler gauge and slip it up under the gasket so you can measure the depth of the channel. then MAKE sure you are on the outside of that.
Otherwise you could try and drill a small hole thru the channel from the inside and see where the edge of the lass is.
Makes a drill-through seem like a bad idea. Hmmm. That leaves a shallow sheet metal screw into the frame, or a clamp setup -- which brings me back to the aftermarket device I thought was too complex! More thought required. Many thanks for the wisdom.
