House Battery
tguerin
I have a 2004 Carver 420 Mariner and my house battery wasn't charging. I checked the battery and it was bone dry. I add distilled water and now the battery is smelling like rotten eggs and is very hot to the touch. I have turned off the charger for safety. Has anyone seen this problem before?
The funny thing is that the battery is holding at 11 volts; could it be that the charger is "over charging" and cooking the battery?
11 volts is a dead battery. It is possiable that you can "restore" it by using a high frequency pulse charger, like the "Battery Minder". The battery has been sulfated by being dry and deeply discharged.
more likely one bad cell so the battery gets way too much charging current and boils especially if two batteries are in parallel because the second battery dumps it full charge into the bad one at a very high rate. It boils out acid and stinks. A lot worse things than reported here happen and that’s why I dont like paralleled batteries but people don’t believe the danger.
And be careful, as it's cooking, it's venting hydrogen gas. As in the "Hindenburg".
it probably sprayed acid so with the batteries removed it will be a good idea to rinse everything nearby then sprinkle baking soda over everything. after it stops foaming rinse off.
Just went through this myself. Replaced all four 8D cells. You probably have a bad cell in the hot battery. My batteries were 4+ years old, so I just replaced the whole set. Wasn't too bad.
