How do you cut window blinds?
Well-known member
In the store they have a machine to cut aluminum mini blinds to width. Naturally since I am replacing blinds on a boat it isn't that simple. The blinds match a window shape that is ВЅ a trapezoid on one side. So I need to cut the top rail to one length and the bottom rail several inches wider and all the slats in between at incrementally longer widths corresponding to their position on the blind. The store can only cut sides parallel and various blind shops also don't have a clue. Boat blinds specialty shops are a zillion dollars more than HD or wallyworld.
I don't know if this will work for you, but I cut some plastic miniblinds using my electric miter saw. I cut mine straight on each side, but I don't see why you couldn't cut at an angle.
eric
A bit labor intensive but remove the slats and stagger them. Secure with tape and take them to Home Depot and have them cut straight. When you line them up you will have a "diagonally" cut
You can probably cut aluminum mini blinds with scissors or metal snips. With the blinds in place I'd mark them to match the window profile, then cut each slat to suit. Finish off the edges with emery cloth. Very likely you can do the whole operation without removing the blinds.
pdecat,
Not sure where you are in Florida, but if I can help you, I will. I am in the blind business in Sarasota/Bradenton area. I have done many boats with Hunter Douglas blinds. They are not easy, but it can be done. You can e-mail me at accurateblinds at verizon dot net. for more information. I also have a web site under that name where you can e-mail me as well.
You can use a Japanese Finish Saw on wood blinds. It looks more like a small meat cleaver but works very well on precise jobs needing a good finished edge in one step.
