How do you post pics?
a) be sure the image has a width of 800 pixels or less.
b) post the image to a publicly accessible website.
c) record the URL of the image.
d) enter the following, using NO SPACES into your post:
[ / i m g ] URL_of_image [ / i m g ]
Bill goofed there...got to watch him! ;)
No forward slash on first set.
The forum code will be already coded for you at sites like photobucket. You just copy the code and paste it with your posting.
Mike is correct.
I bow to his far superior typing skilss... ;)
HOW DO YOU ADJUST SIZE WITH % SIGN? THIS WAS ON A POST A WHILE BACK, SEEMS LIKE A EASY WAY TO RESIZE.
JOHN D
JD, it is better to resize the actual image. By using the per cent screen variable, the user computer still has to download the whole huge file. If you resize the original then the file sizes remain somewhat reasonable.
OK I fixed, but for future? but how does percent work? where do you put it?
John d
I take the easy way and use this button on the poating form menu
hit it and past the url in between
I've been trying to use my photobucket link and it doesn't seem to work. I know I've used it before..........what could've happened?
I'm not having any luck either with photobucket. I'm sure the pic size is too large; I just can't figure out how to reduce it.
I'm trying Kodak............let's see what happens!
Use the bottom selection for photobucket.
Works well :-)
Faster now but still steady
Dave, I've used the last line in Photobucket and all that shows up afterwards is the red X. Kodakgallery seems to work for me now, however, I always used Photobucket in the past without a problem. Just don't get it.
Make sure your coping ALL of line 3. Clink it on once and copy.
I find it easy to use and have never had a problem. Check to copied link to the actual link. Maybe some security setting is not allowing it to go fully through.
faster now but still steady
Trying it again now & it seemed to work!
Bruce, are you on "boated.com" or "boatERed.com?
First will suppress images, second does not.
Bruce, are you referring to my avatar? It shows up on my screen when I read the posts.........why wouldn't it show on yours???
