How do you remove docking scuff marks??
Have several rubber scuff marks on hull from rubber dock edging that are hard to remove. What is the best way to do remove these??
I use a little bit of acetone on a cloth and wipe it clean. They are definately difficult to get off with anything else unless you trailer the boat. If you keep it in a slip then there are not alot of options.
Van
Best way is wax with cleaner in it. Deeper scuffs will take more elbow grease. Acetone takes them off quickly but will also remove some of your gel coat and you will have to re wax the area. So the best bet is to use a product like 3M Cleaner Wax or Restorer Wax which has a mild compound in it. It will remove the scuffs faster.
MichealNJ, I believe acetone will remove the wax, but not the gelcoat! I've also removed those scuff marks using a high pressure stream of water.
Magic Eraser. wet it and it will remove the marks effortlessly. Got floating docks at this marina and of all things, they put in black rub rails So, i have been playing bumper pool with these guys and magic eraser is the ticket.
If you use the magic eraser, you may want to give it a quick light wax over too.
I find that they come right off with a little compound. Wax the area right after and you will never know you had marks.
For future, hang some white fenders off your boat when docking. They're non-marking. They haven't left any marks on boat.
I have docking bumpers installed. These happened when a buddy had it and made a little to fast docking at another dock and actually picked up some of the rubber on the sides. Almost enough where you would think of using a razor blade to remove but don't want to chance scratcher. Magic eraser removes basic marks and stain great but won't remove these. I'll try some compound. Thanks
i had the exact same marks you described, thought i scratched the hull and looked like i needed a blade to take them off. could actually feel the rubber scruff marks on the boat.
Magic eraser and in 30 seconds they were gone.
The reason I said that about the acetone is because when I've used it in the past, i've seen white residue on the rag.
I would not use a magic eraser. It's great on textured surfaces like vinyl but it's too abrasive for high gloss surfaces. It will dull the finish.
Try the 3m eraser wheel in a drill. I used the magic eraser on my boat and it made the gelcoat look terrible. I ended up bringing compound down to fix the fix.
Why won't you guys just use acetone and buff with a little wax? No tools to drag down to the dock, no elbow grease needed. No big deal. Even I can do it! [:-tong2]
Flutterby, No one wants to listen! Acetone is the quickest and easiest way to remove rub marks! A little bit of wax or polish afterwards and it is as good as new. The one thing I hate is having to reach tough areas from a dock with tools. This makes it very easy, and does no damage to the finish.
I use Acetone when I'm in a rush and I have it handy. It's important to wipe it off quickly. Acetone is a solvent for gel coat. If you don't believe me, pour some on your deck and let it evaporate on its own without wiping it up. Every time I use it, I end up with a little white on the rag. It will definitely strip off wax so you will need to rewax the area.
a little spray wax after an acetone wipe down , makes it easy.
Acetone works well as stated several times. You can also use Windex, spray it on, let it set and then wipe. I've also used Goof Off
Just did this this week. Acetone on a rag and wipped up most of the streak. Then a little more acetone on a clean rag to clean up the residue. Finished up with a coat of was on the affected area. I tried buffing off a small area this spring with very poor results and ended up using acetone on that. Lesson learned.
