How does an Anchor Ball work?
Planecrazy
My buddy wants to buy an anchor ball but for we cant figure out how this thing is supposed to work or if it works at all. Any help?
They work well, but you have to be in an open area where you have room to maneuver, for example while fishing offshore. If you're anchoring in a crowded cove in the bay you're not going to be able to use it.
Basically you drop anchor as you normally would. Once you're ready to leave, you put the ring over the anchor line and then clip the ball to it. You then motor forward towards the anchor at a bit of an angle, and the ball slides down the anchor line. You keep moving forward, eventually the ball slides below the water and the motion of the boat and the buoyancy of the ball pull the anchor up and free it. The anchor ends up on the surface right under the ball and then you can slowly go back and retrieve it all. When I do this I drop the anchor from the cockpit, and when retrieving back down and bring all the line back into a bin in the cockpit.
It makes it easy to pull a line up in deep water, there's no manual pulling to free the anchor or lift it up, it's just slowly retrieving the line into the boat. But you need room to go forward on the line and be able to have however much line you had out floating behind the boat. You also have to be very careful not to run over the line. Works well for offshore, but for the bay you're better off with a windlass.
Oh, that makes sense now. I thougt you were talking about one of these:
BTW, if you do an internet search on 'anchor retrieval systems' you'll find some descriptions and diagrams of how it works.
Thanks John, I appreciate it and will forward the info. He boats out of Raritan bay, near Sandy hook NJ and frequently goes offshore. No windlass.
The fishermen in our club all use them here in Lake Erie...pretty slick and JohnC described it perfectly.
Good luck
Niles
I actually lent mine to a guy I noticed was trying to get his 26cc "de-anchored". He was off in 30 seconds.
you have to be careful not to let the rode twist on itself though. Remmebr that your rode will be going from the front of you boat, under the bow rail, to the back of the boat (cleated) them out to the ball and anchor. Then you back down on the rode, you will be coiling it in the cockpit hopefully keeping up with the boat backing down (and don't let all that rode sink 'cause it'll be just as heavy). You will be piling the rope on top of itself and will need to flip over the whole pile in ordetr to pull it back up to the bow to feed back into the hawspipe.
Unless your fishing in 20-30 fathoms, your wasting your time using an anchor ball....
Unless your fishing in 20-30 fathoms, your wasting your time using an anchor ball..."
Actually not 100% accurate. I have used them in 80' of water to get an anchor unstuck. I actually moved forward and the ball and ring disappeared for a good minute, taking all the pressure off the rode and chain.. POP!, up comes the ball. By going passed the anchor the force exerted onto the ring and ball is far stronger than any hand-held manuever. It also takes much of the pressure off the bow cleat when trying get an anchor unstuck
We use them in the Pacific Northwest to pull up shrimp pots at 3-500 feet deep. Works great.
