How much chain
Oasis
I just installed a new Lewmar windlass on my 38 ft Carver aft cabin boat. I cruise the Tennesee river and usually anchor in no more than 20 ft of water.
I am considering getting a length of chain that will hadle that and then anchor use the existing rope spliced to the chain for anytime I need more line.
Any suggestions on the length. The chain is 3/8"
PS. Since chain is so heavy I don't want to carry around any more than I need.
1/3 the length of your boat is a good starting point. if you have a windlass, the best solution is to go to all chain. its not that heavy and you won't be lifting it anymore as the windlass will be doing the work. you'll need less of it in the water with all chain. 3/8" chain weighs about 1 # per foot.
I use the 1/2 the length of the boat as a normal rule, although I have all chain. The more chain lying on the bottom the more weight! I believe added weight is the best defense from dragging anchor. A 50MPH wind on that Carver will move a lot of weight!
Twenty feet of chain is more than enough. It's much more important to have the proper size anchor. I would find out the popular (meaning correct)anchor for the area you boat in and get one size bigger than the anchor manufacturer specs for your boat. I walk down marinas all the time and cannot understand how people can have such nice boats and cheap out on anchors and dock lines, the very things that protect your investment.
Billy K.
never quite understood how the size of the boat is used to decide on chain, except weight.
all chain on a 40 footer maybe a little too much, if you routinely anchor in 20' water, I'd go for 100' of chain which is probably the scope you'll be using most of the time. and when you need more, youy pay out some line...
one issue with line is that it often jams at splice when retrieveing. if it happens when you still have 4 to 5:1 scope, the boat is still holding and you have time to clear it. If it happens when the anchor is alreay off the bottom, you'll be drifting while trying to clear the jam.
and obviously, 5:1 chain will get you a better set... plus get 1 to 2 size up.
If you can't use all chain... go for as much as is reasonably workable.
The key is the weight of the chain causing the anchor rode to lay flat on the bottom.
This means when the wind and sea is up, the force pulling on the anchor is more horizontal than vertical.
The heavier the chain is the more this will be helpful. In other words it's better to have less heavy chain then more light chain and/or line.
If you use 30 to 40 feet of chain for your boat that would be good for most conditions.
I'm getting lazier as it gets later, so: What he said. About the same as what I was going to say.
A lot depends on the windlass. If it does not have the capacity to convert from rode to chain, then it really is a moot point.
Personally, I have had both but hand hauled the anchor on the Regal...all line.
Saint Max is all chain. That is how it came. Frankly, I would not change a thing. In my waters, it is easier to maintain, store and keep clean.
If I had to spend the money for line vs. chain.....their may be an issue.
My 2 cents.
I'm in agreement with the 5 posts above (the more chain, the better). However, when you go shopping, be aware that you probably need, what is it, BBB chain? Check the manual for your windlass. You'll have to purchase from a marine source most likely.
jmcnab and November Charlie pretty much summed it up.
One caveat ( when is there no caveat! ): Consider how you will handle the chain when ( not if ) the windlass fails. On more simply: how much chain, plus anchor can you lift, while it is in the water? If you always anchor in shallower areas, then consider the weight of anchor plus that depth of chain. In most cases, this is not an issue. But if you will consistently anchor in 50 ft or more, for example, then it becomes a consideration. I'm getting old enough where it might become a consideration sooner than for many others... < sigh >
This is, of course, why I carry "anchor wenches"... ;)
Posted - Oct 15 2009 : 22:01:08
Normally BBB for anchor chain.
... What is BBB chain?
BBB is a descriptor that defines the length/width ratio of the chain. It is similar to saying you want a truck vs an SUV. Anyone selling chain will know what "BBB" means...
Not that before you spend a couple of megabucks on chain, try that specific chain in your windlass. While the windlass may specify "BBB" not all "BBB" is exactly the same. Test it before spending the big bucks.
We have done hundreds of nights 'on the hook' over 25 plus years of boating in water dapth also rarely exceeding 20'.
First, get an anchor type proven suitable for most bottom in your area. Second, a boatlength of chain will be more than enough to sleep securely. Sooner or later that wonderful windlass will FAIL & you WILL have to haul it all in yourself.
Thanks all.. It will handle both line and chaing and my first attempt at splicing the line to the chain fed perfectly through the gypsy and into the locke. I plan on redoing the splice since I found better instructions on the web.
Base on the above I will probably look for a good deal (used) on about 75 feet. The chain on the boat is not BBB but works fine.
Thanks again.
The size of chain is determined by what the windlass will accept. "heavier" (larger) chain simply won't work.
When I bought chain I took the Gypsy off the windlass and took it to the store with me, and made DARN SURE the chain would fit.
I found that High-Tensile chain is about the same dimensions as BBB and works just fine for me.
As others have said: use the chain size and type and line size and type recommended by your windlass manufacturer.
ACCO is the largest US manufacturer of marine chain for boating. Prices for ACCO chain will vary widely from store to store. Given the weight of chain and shipping costs you might think that the only place to purchase chain is a brick and mortar marine store, however I can assure you that if you shop around online you can buy any length of ACCO chain you want cut to length, have it shipped by ground and save a lot of money. There is one well-known marine store online (not the largest, incidentally) that I'm thinking of that almost always has the lowest price for ACCO chain by the foot.
BBB (3B) and High Tensile (G4) are both short link marine chains but have very slight differences in size. Both are hot dipped galvanized. BBB is slightly heavier per foot than the stronger G4.
I'm a river and slough boater who anchors overnight a lot. I use 30' of 5/16" BBB plus swivel and 1/2" 3-strand nylon anchor line on a 26' boat. I don't have an anchor windlass so I can get away with using that heavy 5/16" chain on a smaller boat.
Ya one thing is for sure....chain is damn heavy.
Even in the water...once I let out all my chain...about 175 feet... While drifting in about 200 feet of water...it was full of mud and I wanted to rinse the whole thing off. Well I tried pulling on it by hand and could not belive the weight of it. I was very suprised and thankful I had a windlass!!
I boat the upper TN around Knoxville and had the hardest time getting the hook to set in 10 - 20 ft of water. Tried a Fortress than a danforth with 10' of chain plus plenty of rode with limited success. Muddy bottom with rock and who knows what else. A previous thread discussed "more chain" so I tried 30' of chain on a 27' Carver Santego with a 13# danforth anchor, and since that day, anchoring is a breeze. I do wish to mention, I do not have a windlass, but rather the old fashioned bitt. The weight of storage chain isn't the issue, it's when you have to move 50 - 100 - 150 feet of chain my hand when your machine breaks when that weight kills you.
