How to install GPS?
Well-known member
How difficult is it to interconnect a new GPS plotter to various systems such as Autopilot, VHF, depth sounder. There are older systems that use NEMA 0183 protocol. Is it just a matter of getting the correct wires to each box or is there software programming that must be changed??
It greatly depends on the equipment being connected. Mostly a matter of getting the wiring right. Sometimes you will need to change equipment settings so it will know to send or receive NMEA 0183 signals on a specific port. For example, Garmin GPS units often have several ports; one set of wires per port. You need to set the port to the right comms setting (software); then use the right set of wires.
The problems often start when different brands use different terminology for their wires, or have different numbers of wires for communication. It can be difficult to figure out what connects where. There are also usually limitations to how many devices to which one device can "talk" or "listen". You need to read the manuals carefully and come up with a plan before diving in.
I would recommend sitting down with the manuals and mapping out your install. It sure beats the trial and error approach in a bilge.
It's not as difficult as it sounds. Each NMEA circuit can only have one talker [tr] and up to three listeners.
Basically the NMEA out from one machine goes to the NMEA in on up to three more machines. A NMEA circuit is 4 wires, a positive and a ground for outbound and a positive and a ground for inbound. Sometimes the grounds are common and you only have 3 wires on some machines but that's no matter since you can split the ground.
Just make sure you don't have machine A talking to machine B and then machine B talking back to machine A. You get a loop that way and some messages can get lost.
It's this required in some cases? Connecting a DSC radio to chartplotter, for example. The chartplotter talks to the radio, communicating lat/lon data. The radio also talks to the chartplotter, communicating position and distress data for display on the screen.
Bruce. In that other thread a couple weeks ago I remember you inquired about the pass through box one that Brad mentioned. I went ahead and got one and it sure will make it nice to do what you want after you figure it all out. All my stuff is Garmin and it is covered pretty well in the manuals but I do have a Raymarine radio I will tie into the gps.
Good luck
Niles
Niles,
Glad to hear it worked out for you. I didn't want to mention that product - again - lest it seem like I was pimping for them or something. But it would help with what Bruce is looking to do.
So it is really just a matter of hooking up the correct wires? the talker knows what to say and the listener understands what is said even from one brand to another???
Yes. That's the beauty of the NMEA 0183 protocol. Everyone uses the same language.
Tech content warning.
The NMEA 0183 protocol communicates in "sentences". I think they are each 3 characters long, plus a value. The talker will output sentences using the protocol. The listener is programmed to understand certain sentences based on it's function and what the programmer put in. If the talker sends out a sentence that the listener doesn't understand, it will be ignored. (vs. throwing an error.)
That's the beauty of the NMEA 0183 standard. All the talkers and listeners know what to do.
Most VHFs that are new enough to have DSC are smart enough to not pass position data back to a GPS chart plotter. The problem arises when a plotter and autopilot are connected in a loop and the autopilot passes outdated [because NMEA is S L O W] position data back to a plotter and the plotter gets confused about which data us current and can't figure out where it is.
Many newer machines have multiple NMEA 0183 circuits to prevent looping on a single circuit.
The pass through boxes are nice but pricey. You can get a European terminal strip and a project box from Radio Shack for under $10 and build your own.
By "pass-thru box" are you referring to NMEA 0183 expander, multiplexer & buffer devices like Noland Engineering's, Dutec's & Shipmodul's units?
These may help understand the 0183 interfacing: http://www.shipmodul.com/en/index.html (at top left , click on NMEA Info.) That leads to 3 great , really helpful NMEA 0183 links, especially the 2nd one.
Sandy, those links are helpful.
By pass-thru box, Niles and I were referring to a specific product I used to make connections on my gps/radio installation. It's not so much a multiplexer / buffer / expander (maybe and expander) as it is a tool to help make data connections. I discussed in this thread: http://www.boatered.com/forum/topic.asp?TOPIC_ID=121717
S'n'B - Yes, that's probably an option. I didn't feel like taking the time to fiddle engineering a box though. I got mine for a decent price and it save me time on the install. The planning tools that come with the product I bought added to the value and further shortened the time (an paper planner and an Excel-based planner).
