HYDROFOIL
B CHRUN
R THEY WORTH IT AND WHAT KIND WOULD I NEED FOR MERC ALPHA 1 18 FOOT ARROWGLASS 140 IO
This is one of those "hot button" questions. It is often asked, and there is often heavy response, which seems to fall into three groups:
a) "Best thing since Vienna Sausage".
b) "For small boats, in certain specific situations, they may be useful, but likely place much strain on the outboard engine."
c) "If you say that word in earshot of my boat I'm a gonna whoop ya till da cows come home."
My personal opinion is somewhere between b) and c).
Nevertheless, in the interest of fairness, here are a few threads where this has been flogged and thrashed about:
http://www.boatered.com/forum/topic.asp?TOPIC_ID=98820
http://www.boatered.com/forum/topic.asp?TOPIC_ID=94688
http://www.boatered.com/forum/topic.asp?TOPIC_ID=87726
http://www.boatered.com/forum/topic.asp?TOPIC_ID=86577
I hope you find the reading interesting and useful. :)
-edit-
I had to correct the spelling. It was making me above average crazy...
Years ago we sat in the front deck of my buddies house, looking across Puget sound with binoc's watching Boeings Hydrofoil making some test runs.
It was fast. Noisey too. But the most spectacular thing it did was crash in a big splash and a heckuve flash.
We never knew....
Those Air cushion boats might be a better deal.
My buddies had a steering problem. Which ever motor it steered with wasnt powerfull enough and going down a river he ran up on a gravel bar and the skirt of his boat was impaled on a log. That boat would go just about anywhere though. Rough water and muskeg were no problem. The wind was a big problem. His steering motor was not strong enough.
Like Chris said above, plenty of varying opinions on this topic. Generally speaking they work well for smaller boats (say 19' or less) but they don't work as well as trim tabs.
By the way, welcome to the board and please lay off the caps, it's considered yelling.
I had one on a Bayliner 2450. It was there when I bought it. Let me tell you, it really made a performance difference. The boat ran much better...after I TOOK IT OFF. Make sure to do a side-by-side comparison after you buy it (on and off).
And on the other side of the fence, adding a Stingray to my 18' Marada greatly improved performance.
Definately helps on inflatables. For the most part 18 foot on up, the trim tabs will be better. However I put Permatrims on my 150 Suzukis on the Tom Cat to lower the planing speed. It did that, and maybe brought the bow down a bit, but at speeds of 9 to 10 knots, it pushes up large amounts of water around the motors, and even a small amount over the transom....so the use is limited to certain speed ranges in that application.
I just sold a 17ft bowrider with a sterndrive. Before the hydrofoil, the bow would climb so high the boat could barely get on a plane. After, it stayed almost flat and planed immediately. I changed prop pitch from 19 to 17 at the same time, and my top speed dropped from 43 to 38 mph (gps). I don't know if any of that loss was because of the hydrofoil.
