Hydroplane bayliner
  • Thread starter Thread starter blouderback
  • Start date Start date
But seriously, do you think he would get pulled over if he went though a no wake zone at 35 mph?
Stability C.F. Look at where your weight is in relation to your countering forces (no active buoyancy on plane on those little skis) Hit a wake wrong himself and the insurance company would have a good laugh.
I was wondering about fuel consumption once he gets on the foil. You don't have as much hull friction but you do have the same weight being supported. I wonder how that works. Geting up on foil is not free so some power is used for that. Once you are on foil I guess the horsepower used to keep it up is less than that used to go forward in its normal configuration? Thus the higher top end speed. The big advantage is the smooth ride... but , it takes speed to get that ride. There are many times I just want to putt along. No advantage there. Thougts anyone? Pretty cool though! Adam, I don't wish ill will on any boater as long as they do me no harm BUT if they do me harm and have troubles I would still come to their aid. I think it is very cool. IMO Not worth the $ he had to spend to do it but I sure do not wish he would hit a log.
Originally posted by Perry
BB,
Yes, its 5 or 6mph or No Wake.
I've often seen signs that say just "No Wake", as well as signs that say "5 MPH", as well as signs that say both. I bet I could win the argument in the area where it said "No Wake"!
Originally posted by AF
I hope it hits a log!
If you listen to the audio with the video it is clearly stated that the boat puts out " very little wake". That does not mean no wake.It means you are in violation of a no wake law.
Very interesting review from a famous boater on the web.
Independent Assessment of TALARIA III...
[7 Jan 99] When I was last in Seattle I had the pleasure of not only meeting Harry Larsen but actually getting to ride in his hydrofoil TALARIA III. This is the first time I have been able to ride one foilborne and I can tell you it is amazing! When she is sitting in the water it is not obvious that she is very different from any other cabin cruiser. The fully submerged foil system is controlled with a custom build analog computer using an inclinometer (pendulum type device) for roll control and a front mounted ski type of mechanical height control. Mr. Larsen tells me it was an important design criteria not to use expensive aerospace equipment like gyros. Propulsion is provided by an extended I.O. The system is fully retractable and appropriate measures have been taken to minimize damage from drift strikes. Exiting the harbor was much like any other at a slow pace to minimize wake, advancing the throttle, the small block chevy revs smoothly and then becomes slightly louder as the exhaust rises out of the water. The change from hull to foil is not felt so much as a lift sensation but more like some one let go a trailing line that was towing an anchor. The motor revs up with the reduced drag and the boat speed increases. looking aft, the wake nearly disappears. You feel a change in the ride immediately as the waves seem to vanish. there is still some feeling but it is as though you just went from riding in a buckboard wagon to a Caddy. The slamming of waves normal to crossing the wake (we went looking) was completely gone. The real difference was when he let me drive. As the craft became foilborne the response to the helm changed from the feeling of driving a boat to that of flying an aircraft. Albeit a small aircraft that had rudder input tied to the ailerons as a few do but it I found the similarities amazing. Turning the helm banked the craft and directed the boat into a turn with a minimal of lateral acceleration. A very tight turn was possible without stalling. I was most amazed at the stability and feel of control, after becoming comfortable there is no doubt that you could cruise at speed right through most traffic with confidence which Mr. Larsen demonstrated at he took her back into the harbor. He tells me that while it is safe and there is less wake than at all but idle speed hull borne the problem with such a maneuver is that it will scare the wits out of others in the harbor to see this big cabin cruiser moving at 25 knots so close. It would result in someone immediately calling the coast guard or harbor master! Fortunately for us this was a cool fall day and there was no one else around. This would be the perfect answer to big lakes like The Lake of the Ozarks that are nearly unbearable due to the rough conditions from so much traffic. I simply find it ridiculous that there are so few hydrofoils out there. This is a gold mine I swear. For no more than it would cost to have a conversion done, after riding Mr. Larsen's boat there is no way I would spend the kind of money a cruiser of that size cost without having it fit with foils! -- Elliot S. James (esjamesrb2@gr5tcvalley.net )
BB,
I don't know if you would win the argument but you would be the one I’d expect to start it.
he kicked out a nice roller when it dropped off plane just behind the sailboat at the end.
pretty cool otherwise. more efficient, better ride for you and your guests, greatly reduced wakes on the water. the thought of more 'boters' zipping around even faster/possibly closer is a little scary though.
There's no such thing as "no wake" if you're moving. My KAYAK leaves a wake. Here in Florida, NO WAKE means MINIMUM speed.... so I don't think 35 mph would qualify.
Still, I want one!!! Smooth ride, and I'll bet it's fuel efficient too!
Willie:
I would think your arms would be really tired once you got up in the air. lol
Sorry, I couldn't resist.
I'd love to have one on my boat too!
Afte following some links on this foil, I did come across some racing hydrofoil kayaks. Way cool! Search for flyak and foilkayak on YouTube
Well I HAVE been yelled at for going too fast with the kayak (I'm hoping they were just kidding).
The foils would be better on my 17' CC; that thing beats me to death in a chop!
I used to take the foil from Hong Kong to Taiwan. It is indeed a different experience. I would be interested in the fuel consumption. Even if it is the same, The MPG would have to be better. I have never heard of a 5.0L engine producing those speeds.
I would love to have them on my boat.
In that this is a Bayliner, this is a retrofit. This fellow is thinking WAY outside the box. Good on him!
As Kida stated about Hong Kong, and also In Australia, hydofoil craft of all sizes are quite common.
James
