I/O Spacing
Dan Kozusko
I was wondering if anyone knows if there is a benefit to I/O placement close to one another or farther apart? On an 11' beam, I have seen them with manifolds almost touching to at least 2' apart. Which is more efficient or better handling?
I believe it all depends on the rise of the hull. There's a small window as to how high or low the OD sits in the water.
All else being equal, however, I would prefer closer together to get more bite on a hard turn. A straight line would not give any benefit or hindrance--again, all else being equal.
Closer together gives more speed and better performance. Farther apart will steer better at low speeds.
Is there any issue with cavitation?
Love my single screw...
El Sea
Not unless the builder screwed up, your ODs are raised too high, or you are using the wrong prop(s)
There are some competition go-fast boats that have the engines staggered, not side by side but one forward of the other, just so they can get the outdrives as close to each other as possible and as low in the hull as possible. That way, when the boat is in heavy seas, the props are less likely to come out of the water.
Is the speed and performance greatly improved by being closer or minimal? Just curious! Thanx for the opinions.
Dan,
I asked this question when I toured the Formula Boat factory. Their engineering claims that speed is greatly improved, and most go fast boats are this way. I know that I'm happy with the results.
As has been mentioned, there are the definite performance advantages to them being closer together, but for most of us, the better engine access and slow speed handling far outweigh the slight advantages of closely spaced engines and outdrives.
At the recent boatshow here, the Fountain go-fasts had staggered engines. Of course, you're also losing cockpit room. We all know that boats are all about compromise!
Ironically, I am very seriousuly looking at a Formula 36PC with a 13'3" beam and excellent engine access for fluids, plugs, and really, just about everything! I want that boat!
Paul
I had a 30` wellcraft with what I considered centered outdrives/engines. The boat performed well but in the 12 years I owned it I never really became confident or really proficient in docking or low speed, tight quarter operations. I could get it done , but it wasn`t easy. I just figured I was a tool and should take up backgammon or something besides boating. I now have a 40` W/ big propped diesels that you can sleep in between, now when docking or in a tight spot, I look maavelous. Really, really big difference in handling,
Although close spacing may result in speed gains in performance boats, I believe the main reason for staggered engines is to move the center of gravity forward resulting in improved ride attitude in heavy seas at speed.
Staggering the engines also lets the engine sit closer to centerline and deeper in the vee, lowering the center of gravity and keeping the props further in the water.
