In-water storage
7seas
hi,
I have purchased a Quicksilver 270 Sports inflatable and would prefer to leave it in water throughout the year, rather deflate/inflate for every fishing trip to/fro.
Also, the boat has a PVC cover to protect skin from direct tropical sunlight while in water when not in use, which i think helps the fading of fabric and durability of the seams.
Please advise whether this is practical or otherwise.
Thanks.
Welcome to the forum!
If you will be leaving it in salt water, you will have barnacles etc. Even if it is in fresh water only, expect slime.
I also would not expect the plastic fabric to last as long with water storage as it could be expected with "proper" storage. Plastic is not completely waterproof, and over time will absorb water. I cannot imagine that this is good for longevity.
Leaving the cover on will protect the topside. At least it will protect it better than leaving it off would.
I must confess, however, that I do not have first hand knowledge, and might possibly be steering you wrong. But what you describe is something that I would avoid.
Have you asked the manufacturer?
--edit--
Here is a link to the Owner's Manual. ( a PDF file )
Quote from the manual:
"IMPORTANT: To prevent fabric discoloration from marine growth or polluted waters, do not store the boat in water for extended periods of time."
See also the section of the manual relating to proper inflation. Inflatables are somewhat picky about having the correct inflation pressure. However, changes in temperature will cause the chamber pressure to vary, enough that if you iuflate the boat correctly to be safe in the cool of the morning, it will be overinflated during the heat of the afternoon. The reverse is true as well. If properly adjusted in mid afternoon, when it gets cool the boat will be grossly underinflated. ie: Inflatables need constant attention.
I'm guessing here, but I saw this in Alaska so it might happen to you.
Right at the point where the sunlight glances off the water, and that same sunlight meets the boat at the water line, you'll get discoloration and some dis-integration of the fabric inside the Hypalon coating.
(I always thought it was the concentration of the Harmful rays from sunlight that penetrated the Hypalon and caused the fibers to unravel or harden and crack???)
What it means is a fabric failure right at the water line during some kind of stress. Like jumping waves or rough water operation.
If the Hypalon holds up, you'll only notice some bulgy looking distortions along the water line.
If the Hypalon stretches to the point you begin to lose air, you could be headed for a bad day on the water.
if its an inflatable, keep it out of the water when not in use and out of the sunlight. they will last forever if you take care of them, but they love barnicles and the sun does a number on the fabric.
