Inflatable Air Floor
kitjv
Does anyone have an inflatable boat with an air floor? If so, I am interested in hearing your likes & dislikes. I am considering buying a Saturn SD365 with an air floor to eliminate the extra packing weight of plywood or aluminum floorboards. However, I am concerned about stability when standing, as well as any adverse effects on hull performance when the boat is underway.
Thank you.
Kit
I have one in my Mercury, and I love it!! My last inflatabble, (Bombard), had slats, and they snapped in two under my body weight.
It's fine as long as long as it's fully inflated . . . it's a little wobbly otherwise. ;)
Nancy
I have one and its great, I keep it filled as hard as possible and makes for a comfortable ride.
Have the merc also.... Rolls up nice... Bought a high pressure pump 110v to fully inflate the floor....
Its a nice dink....
My Metzler had the inflatable floor. It's great for rivers and going to the beach. No worries.
I used it fly fishing and stood up in it frequently. No problems at all.
My niece dropped some fish hooks down in the gaps between the main tube and the inflatable floor.
I had to de-flate the boat to get all them hooks outta there.
I'd always have an inflatable bottom if I had a choice.
You need a high pressure pump--either manual or eletric. I have an Avon Hypalon air floor and it takes 11.4 PSI. I use an electric pump (12 volt).
The air floor will bow up slightly, and they are not quite as rigid as a plywood or aluminum floor. But--the lighter weight, easier assembly and convience of storage more than make up for any minor issues. You can stand up, just as well as on a plywood floor.
My only concern is the Saturn. I had not heard of the brand until recently--what are they made of? Why are they $900 and the comperable Avon or Achillies made of Hypalon is about $3000? In inflatable boats, you get what you pay for. I found that out the hard way--over 30 years ago I purchased a PVC boat, with some "space age" tansom material--and ended up hand holding a 25 hp outboard at 20 miles per hour--fortunately didn't loose the motor--but the boat was a total waste of money.
I had an airfloor. Similar comments to above, but also had this weird rippling that occurred while on plane. It made me very uncomfortable. The air floor sort of buckled. I used to sit on the floor near the engine and the floor would ripple about 4 inches or so. It didn't happen constantly, just occasionally while on plane.
I now have a wood floor and find it a bit more stable and no rippling! What a pain in the butt to put together though. The air floor was much easier in blowing up and putting away.
I have a wood floor "Baltic" - similar Korean manufacturer as the Saturn. It's PVC, and as well build as some of the big names. In a world of getting what you pay for, I think they are an excellent value.
The wood floor is heavier and much more difficult to set up. Our stays inflated all season. The air floor is lighter, easier to set up, cushions impact on plane as well as crawling around. They flex too much for some. For me I like to be able to load the pile of beach stuff and heavy cooler with sand on the bottom, dog with sandy claws, etc... without having to worry about the floor. Some have said that is a needless worry, but for me I am just more comfortable with the wood version.
I've had them all, RIB, wood floor and now air floor.
The convenience of the air floor if what sold me this go around. I can break it down very quickly and set it up quickly. The ride is a bit flimsy but I don't care this time around. My kids are starting to learn how to drive it so I don't want them going to fast any way. I put these cool trim tabs on (thanks for the heads up on this one Rommer!)and the boat rides much much better now. The bow stays flat instead of point up to the sky when taking off. Standing is not the same as a wood florr but this again is a trade off for ease of assembly/disassembly.
Wood floors are a pain in the a$$ to put together but they ride a bit better than the air floor. I will never own a wood floor boat again. After 4 or 5 years you will be buying new wood floor boards after they start falling apart. Not cheap.
RIBs are the best for ride, stability, standing and speed but not easy to store.
Jonathan
I know you meant the other Bob, but let me weigh in here too. I had one of those Bravo BST pumps. Absolutely loved it. It is a dual stage, battery powered pump. You can set the pressure you want then let it pump away until it reaches the pressure than stops.
Bravo had some problems with the high pressure side, but has since fixed the problem. I had one of the originals and the high pressure side died in about 6 months. Bravo replaced the pump free for a new one with the improved high pressure pump.
It was quick, easy to use, did great sucking the air out for put-away. Only problem, it was expensive.
Air floor all the way for all around convenience! Non RIB solid floor is too much of a PIA
I had a Achillies air floor & it was a good boat - now have a Zodiac Air floor And It's very good as well
I found that the air floor in my Zodiac would ripple if I didn't get enough air into it.
With the proper (USE A GUAGE) amount of air it is very steady, performs and planes faster.
Bob H.
Where did you purchase the Bravo brand pump? and how much?
Dan
I also have the Baltic. 8.5 feet air floor and I paid 645 with shipping. Korean made. Its made out of the same material as my quicksilver was. So far its great if it lasts 3 years I will buy another one and still be ahead.
NAncy,
I went all out on the pump. After years of buying the 50 dollars jokes I Purchased the METRO Magic air deluxe model pumps to 3.5 psi runs on 110 volts... I use it for the dink and my inflatable island with slide.. its huge .... then everyone borrows it ... In two years only failure was the hose... ( IT GETS HOT ) from the air flow ... they sent me a new one 2 years later no charge ...
paid 150.... Its made by a vaccum company... google it
I`ve had more than a few dinks, I now have the Baltic 8.5 with the air floor. Hands down my favorite. I don`t even use davits, it`s so light I pull one side up on the platform, grab it by the bow and flip it up, tie it with its bow and stern line. Done. I use a 4 hp 2 stroke, it planes with me aboard, not with 2.
