If you are buying used then either get it really cheap or almost new. Inflatables have a finite lifespan and once they get to a certain point they no longer have any value at all. Kept out of the sun and properly cared for an inflatable can last 10 years. Poorly cared for it can be toast in as little as 5 years. Some brands have a history of coming apart at the seams after only a couple of years.
A RIB doesn't weight that much more than a wood (or similar material) floorboard model. More, yes, but once the weight of the inflatable passes 100 pounds you aren't going to be picking it up and man handling it anyway so another 20 pounds isn't a big deal. The hard bottom of a RIB cab be well worth the extra weight and money.
If you want to row, the RIB is the best way to go. The hard keel allows the boat to track well so all your effort goes towards getting you to where you want to go instead of zig-zagging. The RIB is also reasonably sea-worthy even with a tube deflated (just don't sit on that side.....)
The real down side of a RIB is that it won't break down into a smaller package for transport. I don't find that to be a problem. The wooden floor model that I had before my RIB would take me a couple of hours, a six pack of beer and a lot of colorful language to get put back together after I took it apart.
With a 5 Hp or less you will be "putting" where ever you go. If you bump up to 10 Hp you can Zip! Two or three adults in a RIB with a 10 Hp can fly along at 20 MPH or more. I can even pull a wakeboarder behind my 11' RIB with my 9.9 Nissan. Here is a link to a little video showing it (note that the rider is ~190 lbs.....)
http://rodm7.tripod.com/
The down side of a larger motor is that they get pretty heavy. While it may be okay for carrying from point A to point B the real issue is when you have to muscle the motor on and off the dinghy, especially if the water isn't dead calm. If you have any kind of hoist that can lift the motor over the side and lower it down it would help a lot.
For a long time I simply tipped my inflatable up on the swim platform. I would wrap a pair of ropes over the top, feed them under the bottom then tie to the swim platform. Two people heaving on the lines from inside the boat could pull it up onto the platform and then up on edge. Later I installed the davit system, which worked a lot better. They hold the dinghy off the back of the platform so you could still go out on it if you needed to.
Like Monterey said, don't get your dinghy longer than your boat is wide, you don't want it to serve as a fender when you come into docks.
I have owned three different inflatables. My current boat, an Achilles hard bottom, is the one I have enjoyed the most. I have abused that boat so badly and it has taken it all in stride. It is about 7 years old now, and accept for anchor flukes ripping the pontoon incident the tubes have held up fine.
Rod
